#11 (permalink) | |
The main jets come on full at higher rpm's, provided the vacuum slides are working properly and raising the needles like they should.
#14 (permalink) | |
by the way the idle mixture screws should only really have an effect on closed idle mixture to 1/8 throttle for the most part. Do you have a manual for this? you should get one if not, at least something real close to what you are working on.
#15 (permalink) |
If you just want to get them done, without the confusion. I always just do them like this, when one valve is completely compressed like the intake,adjust the exhaust of that same cylinder,it will be in the closed position. Then compress the exhaust, and adjust the intake. Just make sure the one that's compressed, is all the way down, so their not overlapping each other , chances are slim though.
![]() HD 2003 1207cc 100thAnniversary Last edited by Coolride; 01-05-2013 at 10:29 AM. |
