VLX Air Filter replacement - Honda Shadow Forums : Shadow Motorcycle Forum
Old 12-29-2012, 10:41 AM   #1 (permalink)
Steve-O's Avatar
Default VLX Air Filter replacement
What's a good replacement air filter for a 2002 vlx 600?
2009 Stratoliner (mine), 2008 Stratoliner (hers), 2010 Harley Rocker, 2002 Honda VLX
Steve-O
Steve-O is offline   Reply With Quote
Old 12-29-2012, 02:38 PM   #2 (permalink)
Super Moderator
old dad's Avatar
I make my own using the oem filter frame. Take off the metal plate,(save to put back), cut out the paper pleated filter. Buy the store brand car air filter that has the same size paper pleating. Get some gasket seal(in tube). Cut the new paper filter to fit the oem filter frame and use the gasket seal to seat and seal the edges. Now take the metal plate and some small sheet metal screw and reattach the metal plate.
Has worked for me for over 50,000 miles. Cost about $11.00 for the car filter and few bucks for the gasket sealer. It beats spending $60.00 or more for the oem filter of which I once bought.(this gives me one on the bike and one refabbed for immediate replacement when needed)
2006 vlx
Old 12-30-2012, 08:11 AM   #3 (permalink)
Steve-O's Avatar
Great idea. But is there a performance air filter for these bikes? Not that I'm going to get much more performance, but I'm wanting to change the pipes and air filter to see what that does.
$60 for an air filter? Yikes!
Steve-O
Old 12-30-2012, 08:29 AM   #4 (permalink)
Super Moderator
old dad's Avatar
Steve, for sure if you change up the air flow you will need to put in a jet kit. Anytime you play with the air flow you will need to do this or at least adjust the a/f screw.
Keep in mind the vlx has 34 hp, just changing the pipes and air filter really won't do a whole lot towards performance. You will get a little more with the 4* timing mod, plus pipes, plus jet kit.
2006 vlx
Old 12-30-2012, 09:54 AM   #5 (permalink)
Steve-O's Avatar
Do you have instructions on the timing mod or is this something I can google?
Steve-O
Old 12-30-2012, 11:26 AM   #6 (permalink)
Scrapdog2grand's Avatar
Aced It just posted something, they made it a sticky!!
you have two ignitionpick ups on that, so they will have to be advanced properly together.
1999 VLX
1998 SA750
2003 SA750
Old 12-30-2012, 12:01 PM   #7 (permalink)
Super Moderator
CleoBen's Avatar
There is not an aftermarket air filter that I'm aware of for the 99 and newer VLXs.
01 Spirit 1100
Link to the Forum Rules
CleoBen is offline   Reply With Quote
Old 12-30-2012, 05:02 PM   #8 (permalink)
Super Moderator
old dad's Avatar
K&N has on I believe,,
K N Air Filter 99 07 Honda VT600 Shadow VLX Deluxe | eBay
doesn't look much different than the oem. Filtering material looks different,,close to oem price too.
2006 vlx
Old 12-30-2012, 05:08 PM   #9 (permalink)
I got a VLX K&N for $41 on Amazon. Works fine. Mostly got it because it's rechargeable, not for any supposed performance benefit.
Bowie- is offline   Reply With Quote
Old 12-30-2012, 05:18 PM   #10 (permalink)
Originally Posted by Bowie- View Post
I got a K&N for $41 on Amazon. Works fine. Mostly got it because it's rechargeable, not for any supposed performance benefit.
Hows the fit, I didnt get one for the wifes VLX cause the ratings that I read said it didnt fit quite right
1999 VLX
1998 SA750
2003 SA750
