Hole saw mod for 2012 vt750C2 - Honda Shadow Forums : Shadow Motorcycle Forum
Old 01-02-2013, 10:24 PM   #1 (permalink)
Torque's Avatar
Default Hole saw mod for 2012 vt750C2
Really thinking about cutting the resonators out of my pipes to get me through this riding season because I can't really afford the set of cobra pipes I want. Is it worth it to cut them out, or should I just save up and do it the right way the first time?
Torque is offline   Reply With Quote
Old 01-02-2013, 10:42 PM   #2 (permalink)
davelisowski's Avatar
i have a set of OEM pipes from a 2009... you could use those to hole-saw mod in case you don't like it...
Live to ride another day!
davelisowski is online now   Reply With Quote
Old 01-02-2013, 10:48 PM   #3 (permalink)
cza888's Avatar
I would save up and get a nice set of cobra's or V&H
got a nice set of cobra streetrods on my C2
just my .02 cents
You may not end up where you thought you
were going, but you will always end up where you were meant to be
__________________________________________
2007 Spirit 750
cza888 is offline   Reply With Quote
Old 01-02-2013, 11:44 PM   #4 (permalink)
mlr
mlr's Avatar
Save up get the good pipes. look for brand name pipes on eBay I picked up my HK pipes under 300.
mlr is offline   Reply With Quote
Old 01-03-2013, 12:12 PM   #5 (permalink)
Torque's Avatar
I know there is 2 schools of thought on this topic. My problem is really just me. I want to put a nice set of cobras on, but then I feel like I will just want to do the fuel management and the air intake. The bike isn't even 3 months old yet and I'm itching to change every last thing.
Old 01-03-2013, 12:58 PM   #6 (permalink)
tgelphman's Avatar
Send a message via Yahoo to tgelphman
Originally Posted by Torque View Post
... I want to put a nice set of cobras on, but then I feel like I will just want to do the fuel management and the air intake. The bike isn't even 3 months old yet and I'm itching to change every last thing....
For a relatively inexpensive entry it sure is an expensive hobby
05 VLX 600 - first bike.
tgelphman is online now   Reply With Quote
Old 01-03-2013, 02:08 PM   #7 (permalink)
Torque's Avatar
If I put the cobras on without the fuel management upgrade, will the stock computer balance out most of the issues, or will it run poorly? I understand that the chip remapps the system to make it run better, but will it run worse if I don't install it right away?
Old 01-03-2013, 03:17 PM   #8 (permalink)
Phantomjr's Avatar
The US VT750s with FI do not have an O2 sensor, so there is no feedback into the ECU. The $600 Cobra controller senses how the engine is running and adjusts; the lower price unit doesn't measure anything. You can adjust it manually by judging how the engine is performing and comes from the factory adjusted for Cobra exhaust systems.
John
Conway, NH
2010 Shadow Phantom
Phantomjr is offline   Reply With Quote
Old 01-03-2013, 03:45 PM   #9 (permalink)
Yes, yes it is!
2005 VT750DC Shadow Spirit
DCHAVOC is offline   Reply With Quote
Old 01-04-2013, 05:42 PM   #10 (permalink)
Mark J's Avatar
The Cobra intake works just fine with OR without the FI2000 control. It will pick up some HP with the FI2000 however. My preference in pipes, and gives results much deeper in tone than aftermarket, is to do this... First do the hole saw mod, then make/buy straight through baffles, (with spiral slits). Build up one end if necessary for good fit, and wrap well with first glass tape, then 1/2" batting, then selvedged edge glass tape again. Glue seams with heat proof silicone, and clamp ends of the 6" wide glass tapes with SS cinch ties, or wire. Compress the pillow of glass around the straight through baffle to get it in there, and use a couple of machine screws to hold it in place. It should outlast the bike!
This makes your pipes just a bit louder, but not obnoxiously so, and definitely deeper than aftermarket pipes. Its a DEEP bass note that sounds good in my book, not really loud pipes with a cave like echo.
I also prefer the look of factory pipes.
Mark
Mark J is offline   Reply With Quote
