Cam chain tensioner bolts - Honda Shadow Forums : Shadow Motorcycle Forum
Old 01-06-2013, 06:55 PM   #1 (permalink)
corner27's Avatar
Default Cam chain tensioner bolts
On my 83 750, I noticed that there is a bit of oil dripping from the cam tensioner bolt. I tried tightening it, but it feels like its stripped. I would like to try putting a slightly longer bolt in to see if it will grab some good thread. The question I have is, if I take the top tensioner bolt out, will the tension stay in place? I'd hate for it to shift and not be able to align the new bolt up.
1983 VT750
corner27 is offline   Reply With Quote
Old 01-07-2013, 11:08 AM   #2 (permalink)
corvin's Avatar
Send a message via MSN to corvin
Just keep the lower bolt tightened.
About grabbing healthy thread,possibility is low.
But worth to try.
Honda VT 500 C 1983
corvin is offline   Reply With Quote
Old 01-07-2013, 04:25 PM   #3 (permalink)
Scrapdog2grand's Avatar
I wouldnt go to much longer on the bolt, 2mm tops, even that may be too long.
try adding a little sealant Hondabond HT, or permatex gray around the sealing washer as well.
1999 VLX
1998 SA750
2003 SA750
Old 01-07-2013, 09:07 PM   #4 (permalink)
corner27's Avatar
I took the bolt out today and it apears to be a special bolt. I put some permatex on the bolt and washer, so hoperfully that will seal it enough.
1983 VT750
Old 01-07-2013, 09:34 PM   #5 (permalink)
Good Luck on this situation...
Let`s Ride!
`98 VT750 A.C.E.
www.mrf.org
www.MSF-USA.org
http://www.ama-cycle.org/
