Easiest is get someone else to do it. I have a 2001 and have not came up with an easy way it is a pain in my opinion. Takes me at least 45 min start to finish
Dave
I have a PDF from the online manual which shows step by step. I tried to upload it but the size is too big. If you send me a personal email i can send you it that way if you like.
Take off both side covers,,loosen and remove both cables,,- & +. Neg from the left side, poss from the right side. Slide the battery out on the right (pipes side) side.
