So today on my ride, I noticed that my turn signal indicator light was stuck on. I could see that my right front and right rear running lights were not on. When I turned on the turn signals, they worked as they should, but when I canceled them, the indicator was stuck on again. I disassembled the switch and cleaned it with electrical cleaner. I removed the old grease. I do not have any dielectric grease on hand to regrease it with, so I just put it back together for now. I figured that the cleaning would have solved the problem, but it didn't. Any ideas?
Sent from my C5155
I'm only guessing here so don't bash me if I'm wrong but might be something to look into, but what turns that light on may be a relay and the relay may be failing and not turning it off, I'm sure someone who knows a little more about the electrical system will confirm or say I'm wrong lol but food for thought.
Dauntae
#4 (permalink) |
But it still flashes as it should, so I don't think its the flasher, but I could be wrong. I've noticed that since it got cold, the switch has been acting up a bit. Thought mabey a cleaning would have helped, but I guess not.
Sent from my C5155
#5 (permalink) |
The running light ,and turn signal lights are kinda 2 seperate but related circuits.
both circuits run throught the turn signal switch, they're is 2 seperate switches in there, one for each circuit. When you say the indicator stays lit, are you reffering to all the lights on the side you just signaled for? and are they flashing or on steady? does the running light come on when the indicator goes out? you only have running lights in the front normally, unless its been modded. and you do have a normal turn signal flasher that could be getting stuck closed. causing the indicator to stay on, but that dont sound right. How do you turn them off when they get stuck on?
#8 (permalink) | |
Sent from my C5155
#10 (permalink) |
Super Moderator
^ again this,,,and the best way to start any resolution is "KISS" keep it simple stupid (not calling anyone names) way too many members suggest right off the bat to tear into this or that when checking the simple things first often resolve many issues,,and is way cheaper.
2006 vlx ![]()
