What kind of a tool is needed to fix the light on the light bar on a 2011 honda shadow VT750C.
My left driving light somehow got loose and i tried to hand tighten it but it comes loose again. Is there a special tool to fix the upper lamp (not the signal but the left side headlamp on the light bar. |
None of the shadows come stock with a light bar, Put up some pics so maybe one of us will recognize what brand light bar you have (May have been added at the dealer as a extra on your bike) and will be able to help you as there are a few different types, As for my light bar there are threaded studs that come out of the lights them selves and a nut that threads onto the stud on the bottom of the light bar, Not visible unless you looking from underneath the light bar however. So post up some pics and someone will know how there put together.
Dauntae
#3 (permalink) |
I bought mine new but I guess the dealer must have added them.
The 3 pics are attached. Each zooming down to the problem area. ![]() ![]() ![]() Sent from my iPhone using Motorcycle.com Free App |
#4 (permalink) |
You are going to remove the turn signal from the mount, and then most likely use a deep socket or wrench to get up on the nut above the turnsignal and tighten it down.
#5 (permalink) |
Scrapdog
Thanks for the response. But since there is a wire going thru the threaded pipe a deep socket cannot be used unless it has a slit on a side. I am looking for something like that in metric sizes. Any suggestions? Also once you tighten it you cannot get the bolt on the inside portion of the signal is not accessible as the light bar is in the way. So it has to be tightened a little off and then move it in place after fitting it which causes the light to be loose. Maybe I should use thread lock on it. What a bad design. Sent from my iPhone using Motorcycle.com Free App |
#7 (permalink) |
Since a light bar is not standard on the shadows maybe the nut on the light is not metric. Does anyone know? Or do I need to get a micrometer to figure that $$$
#9 (permalink) |
I opened the signal lights and the nut is in there. The bolt is of course a threaded pipe because the wire goes thru it. And this the problem of tightening it adequately.
