How do I Take apart rear shocks ? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 7 (permalink) Old 02-25-2013, 12:48 AM Thread Starter
Spitse's Avatar
I have a 83 vt500. I want to paint the rear shocks and springs. How do I take them apart? Will it be under load when it comes apart and if so, do I need a tool or something to compress?
'83 VT500C
Spitse is offline
post #2 of 7 (permalink) Old 02-25-2013, 09:16 AM
GilaMinumBeer's Avatar
You would need a tool to compress the springs. Other than that, I'm not sure you can take the apart without some presses or specialized machinery.
04' Honda Shadow Aero: Mutazu, Harley Davidson, Dynojet, Vance and Hines, Tiny Tach, Shindengen, Progressive, EBC, Colorite, Edelbrock, TJBC, Emgo, Optimax, and Metzeler.
GilaMinumBeer is offline
post #3 of 7 (permalink) Old 02-25-2013, 12:59 PM Thread Starter
Spitse's Avatar
Do they unscrew or off the shaft part or the base? I have looked at the parts picture, but I am having trouble understanding the actual method.
I have a Polaris RZR and it was pretty straight forward. Unscrew the retaining rings and slide off, but they are adjustable, and these look like they are not.
'83 VT500C
Spitse is offline
post #4 of 7 (permalink) Old 02-25-2013, 01:32 PM
Disassembly/reassembly of the shock/spring unit is tricky, requires a special spring compressor and DANGEROUS.
Removing the intact assembly from the swingarm/frame is just a matter of removing the mounting bolts at the top and bottom.
Black Beast = '71 CB750
Lazarus = '86 VT1100C rescued from a salvage yard.
GrumpyOldMan is offline
post #5 of 7 (permalink) Old 02-25-2013, 04:36 PM Thread Starter
Spitse's Avatar
Looks like I will be getting the spring compressor.
From what I have found, the shaft on the shock is threaded. Once springs are compressed, you unthread the top spring retainer/mounting eye and then you can remove springs.
'83 VT500C
Spitse is offline
post #6 of 7 (permalink) Old 02-25-2013, 10:56 PM
About the same as struts on a car. Will need some way to compress spring. BE CAREFUL!! This is not a job to try with out proper tools. Maybe take to a shop and let tech take them apart for you.
trabb47 is offline
post #7 of 7 (permalink) Old 02-26-2013, 11:21 AM Thread Starter
Spitse's Avatar
I ordered some spring compressors for motorcycles from eBay. $17 for a pair.
I did some YouTube research. Probably best for how not to do it. One video had a large person sit on the bike and zip ties were used to keep springs compressed. Then vice grips were used to compress further. That is when I decided to order the correct tool.
Thanks for the tips.
'83 VT500C
Spitse is offline
