My 83 750 runs great for the most part but every once in a while I get a slight hesitation in 4th 5th and 6th gear when I shift at about 6,000 RPMs. It doesn't do it all the time but randomly. Any ideas of the cause?
C Chris72 160 posts · Joined 2015 Add to quote Only show this user #2 · Jul 6, 2015 Any modifications to the air intake or exhaust?
R robertj298 Discussion starter 65 posts · Joined 2014 Add to quote Only show this user #3 · Jul 6, 2015 Yep the previous owner replaced the stock rusted out pipes with pipes off of a sportster.
C Chris72 160 posts · Joined 2015 Add to quote Only show this user #4 · Jul 7, 2015 Did you upgrade the jets?
R robertj298 Discussion starter 65 posts · Joined 2014 Add to quote Only show this user #5 · Jul 7, 2015 The jets were upgraded. What's funny is it only does this one in a while.
C Chris72 160 posts · Joined 2015 Add to quote Only show this user #6 · Jul 7, 2015 Maybe there is something floating around one of the carb bowls. Check your plugs too, maybe first. See if one is fouled.
