Well unfortunately it looks like I need a rebuild kit for my front brake master cylinder it has some seals that are ripped that being said I also need a brake handle and it seems people will often sell the master cylinder and a brake handle for slightly less than the cost of a rebuild kit that being said I was wondering which ones will swap in and work correctly can I use one of many shadow, Magna, Nighthawk, Cb, saber??? What about off of sport bikes like CBR's and things like that?
Check on ebay for available parts. Better to stick with the dual front disc brake models, because the size of the bore in the master is calibrated to to provide the amount of fluid needed for 2 calipers.
I have a 84 shadow 700...i ended up buying replacement aftermarket ones on ebay for round 20 bucks each ..cheaper than rebuilding them and they work great!..make sure you measure your handle bars before ordering. Mine measure 7/8" but 1" is also available.
Related Threads
Honda Shadow Forums
1.6M posts
82.9K members
Since 2007
