I posted this on the introduction thread but figured here in technical may be where it can reach other eyes for this unique issue..
Yes, the bike has gas and in the on position..
I'm having one heck of a time with this bike..
What happened, 03 750 A.C.E. Has been ridden for years without issue. Then a police officer pulls me for my bars being too tall (1in one so higher than my shoulders) gives ticket and refuses to let me ride it due to safety concerns he says.... So middle of the night my friend has to meet me with his truck and him and I load it up and transport the bike home.. After successful transport without incident, bike will only crank but will not turn over.
What I've done so far,
Bike turns over for a second or 2 when I shoot carb cleaner directly into carbs.. That told me fuel issue, so I have replaced the gas.. I have replaced the canister type fuel pump under the seat, I have removed the carbs cleaning the section where the floats are with a standard carb rebuild kit I.e. The 10mm brass and pin that's inside it connected to the floats. Removed the pilot jet and cleaning with carb clean and dip. I have traced fuel through each step of the line from pet **** to in line filter to the fuel pump that I replaced to the next white plastic connection up to the carb inlet having gas come out at each junction. I have checked all the fuses, made sure all the switches are on and the right places. I've replaced the spark plugs.. I literally replaced and checked every part of what a gas engine needs to run. Air, spark, fuel... It just cranks and cranks but does kick over a little bit with carb cleaner.... I am at my wits end here.... What am I missing?
I am not well versed on the proper lingo as this is my first post so I tried to give as much information as possible....
