Fuel coming from valve cover - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 24 (permalink) Old 01-08-2017, 09:14 PM Thread Starter
I got my 07 shadow 750 c somebody let it sit for 3 years with the fuel on I pulled the carburetor apart check diaphragm clean all the Jets and needles when I get it to start it's it's fuel out of a vacuum line that comes from the top of the rear cylinder valve cover to the air cleaner subsequently filling up my air cleaner box with black fuel what could be causing this thanks for your help in advance
Sent from my SAMSUNG-SM-G900A using Tapatalk
axxer4200 is offline
post #2 of 24 (permalink) Old 01-08-2017, 10:34 PM
PhantomRider64's Avatar
My first thought is that the entire motor is full of fuel. Have you changed the oil and filter??? if not it would be a good place to start.
Some more knowledgeable folks should chime in,,,
There is nothing like your knees in the breeze!!!
2013 Shadow Phantom
Previous Bikes
1995 Suzuki Intruder800
1982 Suzuki GS450L
Ride Bell By Old Dad.
Ride Cross gifted from Captain D
PhantomRider64 is offline
post #3 of 24 (permalink) Old 01-08-2017, 10:39 PM Thread Starter
I haven't just due to if it is dumping fuel didn't want to waste money but now that I have ran it a few times it needs to be changed I don't want to wash the bearings also the crank case nor the cylinder seems to be filled with gas but is coming out the niple off the top of the rear cylinder valve cover
post #4 of 24 (permalink) Old 01-09-2017, 12:46 AM
Sundown's Avatar
The Black fuel may well be fuel mixed with oil. The hose going into the air box is supposed to be a vent , but when there is too much oil in the crank case it blows the excess into the air box. I can't be 100% positive as I'm not there , but it could be the fuel going into the cylinder as the shut off is open , then down into the crankcase and finally blowing into the air box.
So if that is what it is doing , it is kinda doing what it is supposed to. Just way overwhelmed due to the fuel pushing past the carb float and all. In fact the oil level might start overflowing when you open the filler hole.
So. Make sure the fuel petcock is off. Then Drain the oil , change the oil filter and refill oil . Don't go over the higher oil mark on the dipstick.
Make sure the gas tank is empty , Then again make sure to turn off the fuel petcock , and then fill the tank with clean gas and a few oz. of "SeaFoam". Open the petcock and try to start it. Let us know how it goes.
There may be a problem to deal with in the carb. but start with the above and we can go from there.
Good Luck.
"At all times you are only where you really want to be," unknown old man in a desert lightning storm.
Sundown is offline
post #5 of 24 (permalink) Old 01-09-2017, 12:51 AM Thread Starter
I will give it a shot and see what happens thanks
post #6 of 24 (permalink) Old 01-09-2017, 09:53 AM
Ramie's Avatar
Is it only dumping the fuel when it's running?
1998 Valkyrie Standard
2001 Valkyrie I/S
Ramie is offline
post #7 of 24 (permalink) Old 01-09-2017, 10:08 AM Thread Starter
Yes only spitting when running
post #8 of 24 (permalink) Old 01-09-2017, 11:17 AM
swifty2014's Avatar
If it is actual fuel it is a fire hazard so be careful. It must not be getting into the cylinders since you had it running a few times and you didn't say it was flooding. So I am thinking it is condensation mixed with old engine oil and smells stinky like dirty oil that sometimes has a bit of a fuel smell. But it is too much for normal venting.
If you take that hose loose and run it and capture some of the fluid in a jar, then take it 20 feet away and pour it in a pie pan and try to light it , it will show about how much actual gasoline is in it.
It may be just condensation and blow by and that would be at least safer to be starting the engine. Change the oil and make sure it is not over filled and go from there. Are you checking the oil level with the bike held straight up ?
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is online now
post #9 of 24 (permalink) Old 01-09-2017, 11:44 AM Thread Starter
I was checking with a lean
post #10 of 24 (permalink) Old 01-09-2017, 08:04 PM
Phantomrider is spot on, crankcase is full of gas. Do not run it anymore until you change the oil & filter
FISHTALES is offline
