excessive pressure in the crankcase - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 8 (permalink) Old 03-19-2017, 02:18 PM Thread Starter
this is the second honda in my life and it came to me too tired. so the problem is- high oil consuption, smoke from pipes and when after a ride I open a filling cap , too much gasses are running away. When i disconnect i rubber pipe from a rear head cover there are no air moving , but they should i m sure. So what is it? is it a problem with the breather or something? i dont know is there any valve in a rear head cover. I suppose i should dismount the engine because the frame does not let me to dismount the head cover
Ruslan Bazarbaev is offline
post #2 of 8 (permalink) Old 03-19-2017, 02:24 PM
swifty2014's Avatar
Remember to remind us old guys with bad memories which bike it is.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #3 of 8 (permalink) Old 03-19-2017, 02:46 PM
Super Moderator
Phil's Avatar
I would do a leak-down compression test to determine if the piston rings are bad.
If the rings are bad, gasses from the combustion cycle would leak past the rings into the crankcase.
High oil consumption could also be a sign of bad piston rings.
Good luck,
Phil
1973 Yamaha RD-350
Sterling Heights, Michigan
Phil is offline
post #4 of 8 (permalink) Old 03-19-2017, 02:46 PM
smilie's Avatar
Make sure your crankcase vent is open. Not sure of your bike, but your service manual should show you where it's located. It's usually on the lower right in front of the swing arm pivot.
2007 Shadow Spirit VT750C2, Ride bell by h13man, Ride cross by Capt D
smilie is offline
post #5 of 8 (permalink) Old 03-19-2017, 03:04 PM
swifty2014's Avatar
Here is a photo of my 1983 750 engine vent system if that is the bike you were refering to. The vent pipe on top of the cylinder hear has no valve and should be free flowing. Then the vapor goes through a liquid separator tank and the vapor continues on to be re-burned into the air filter box. The tank can be drained of liquid periodically. A little bit of liquid drained is normal.
1983 750 Shadow
From the past=
post #6 of 8 (permalink) Old 03-20-2017, 04:39 PM Thread Starter
The bike is Honda VT 750 c 86 according to documents. I saw something like tube on the back side of rear cylinder , that connects crankcase with a head. It seems to me that it's jammed or something, because the pressure in case does not go through it into the head and after throughout the breather into the frame
post #7 of 8 (permalink) Old 03-20-2017, 04:41 PM Thread Starter
An addition - I saw a tube in manual. I don't know whether it is there. Tomorrow I'll dismount the engine
post #8 of 8 (permalink) Old 03-20-2017, 09:17 PM
swifty2014's Avatar
According to the 1986 manual there is a short vent host to the air chamber on top of the head. So maybe if you have an air compressor you could blow a little air into the top of the cylinder head pipe, and with the oil dip stick out, see if it goes into the crankcase area easily. I seems to me that if you have an engine problem with too much blow by it would have a lot of oil in the air cleaner and that vent tube.
1983 750 Shadow
From the past=
