Float (pin holes) - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 18 (permalink) Old 03-20-2017, 12:43 PM Thread Starter
750genie750's Avatar
Float (pin holes)
If a float floats on gas would that be a "solid" indication that it does not have pin holes?
"Let me die a young man's death, with a fully operational motorcycle"
750genie750 is offline
post #2 of 18 (permalink) Old 03-20-2017, 12:52 PM
Super Moderator
Phil's Avatar
It would be a pretty good indication but it might depend where the pin holes are, their size and how many there are.
Think of a ship with portholes on the side of the hull, the ship doesn't sink because those portholes are above the water-line.
Just curious, where are you going with this question?
Phil
1973 Yamaha RD-350
Sterling Heights, Michigan
Phil is offline
post #3 of 18 (permalink) Old 03-20-2017, 12:54 PM
If it floats, it's doing it's job.
jpr1968 is online now
post #4 of 18 (permalink) Old 03-20-2017, 02:07 PM Thread Starter
I am experiencing carb issues and perhaps need to purchase an item or two, but only if necessary.
post #5 of 18 (permalink) Old 03-20-2017, 02:36 PM
Super Moderator
Phil's Avatar
Found this on YouTube....
If it's out of the carburetor, and it's a brass float; this is how you can check it:
Phil
1973 Yamaha RD-350
Phil is offline
post #6 of 18 (permalink) Old 03-20-2017, 03:46 PM
What carb issues?
post #7 of 18 (permalink) Old 03-20-2017, 04:01 PM Thread Starter
Mine are plastic! I heard once that if a float cannot float on gas it has pin holes and I wanted to substantiate it.
post #8 of 18 (permalink) Old 03-20-2017, 04:53 PM
Once again, what is wrong with the carbs?
post #9 of 18 (permalink) Old 03-20-2017, 06:06 PM Thread Starter
If I may direct your attention to the thread "Oil over-fill" 3-17-2017 my carb issues and the advise that I'm following is explained. I am considering replacing some parts and my float was one of them until I decided it is still functional.
post #10 of 18 (permalink) Old 03-20-2017, 07:38 PM
If your engine is still flooding then a bad float isn't your problem. A float that has a hole in it will sink and not allow any fuel into the float bowl. You need to check your float height in the carbs.
