Is my fuel **** upside down? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 5 (permalink) Old 03-20-2017, 06:26 PM Thread Starter
This is the off position but looking at the manual it should be rotated 180 degrees. I had it turned where run is up and ran out of gas. I switched to reserve and it still wouldn't start. Luckily the gas station was only a couple of blocks. I put 3 gal in a 2.9 gal tank and it fired right up.
'95 VT 600 C
95 VT600C
Blasbo is offline
post #2 of 5 (permalink) Old 03-20-2017, 06:58 PM
Super Moderator
Phil's Avatar
Originally Posted by Blasbo View Post
Attachment 201385
'95 VT 600 C
It sounds like the knob is on wrong and should b rotated 180 degrees. But I think the knob is slotted and can only go on one way.
Take the knob off and see if the slot was maybe damaged and was installed wrong. It's held on with a small phillips screw.
Phil
1973 Yamaha RD-350
Sterling Heights, Michigan
Phil is offline
post #3 of 5 (permalink) Old 03-20-2017, 11:47 PM
P.S. might want to clean it up a bit... looks a little dusty. just sayin...
WutUGot is offline
post #4 of 5 (permalink) Old 03-21-2017, 12:08 PM
Super Moderator
old dad's Avatar
you haven't seen my pollen covered bike,,pollen is blitzing us in the MB area of SC
2006 vlx , gone but never will forget it.
old dad is offline
post #5 of 5 (permalink) Old 03-21-2017, 05:27 PM Thread Starter
Thanks. I'll add checking that to the list...along with a bath.
95 VT600C
Blasbo is offline
