engine quits while riding then nothing... - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 16 (permalink) Old 05-17-2017, 08:34 AM Thread Starter
happened twice.. once I had to call the "tow" truck!
it's a 92 Steed 600. She started fine, But as I ride awhile, I noticed the engine starts to sputter a little... But when I open the throttle, she seems to respond well...
But as I ride more, the engine stops.
When I try to restart her, I hear the started motor whine, but the engine doesn't turn at all.
I'm sensing there are a couple of different issues. Engine sputtering and engine not turning might be different issues.. or may be not.
any ideas ?
thanks in advance.
idgeek is offline
post #2 of 16 (permalink) Old 05-17-2017, 11:19 AM
How do you know the engine isn't turning over? I would check the battery voltage. A low battery will cause those symptoms.
jpr1968 is offline
post #3 of 16 (permalink) Old 05-17-2017, 11:23 AM
smurfy71's Avatar
Possibly your gas vent, if it's clogged you may have a vacuum in your tank causing it to starve for fuel. Next time it starts to sputter, open the gas cap and see if that helps.
2006 Shadow Aero 750, "Audrey"
Mods/Ad-ons to date:
NC Switchblade
NC Chrome Deflectors
NC Hand Deflectors
Oxford Grip Heaterz
Power Trip Saddle bags
Willie & Max Handlebar bag
Highway pegs (eBay)
Gremlin Bell (gift from my son)
Mustang Seat!
Crash Bars
Vance and Hines Cruzers
Rear Signal relocation
smurfy71 is online now
post #4 of 16 (permalink) Old 05-17-2017, 11:45 AM
ABQ-Jammer's Avatar
This could be a couple of things. Like @smurfy71 1 said, it might be the gas tank vent tube being clogged, and taking off the gas cap will let you know if that's what the problem is, as the bike will start and run fine without the cap on, but when you put the cap back on, it will die a little later. Another possibility is the coils. If there is a crack in the coil, it will run fine for a while, until that coil heats up and separates, causing the bike to die, and not be able to start until it's cooled off enough to get closer together so the spark can jump the gap again, and then runs until it heats up and separates and dies again. You should also check the 3-yellow wires, as that can cause all kinds of trouble, including not starting or dying. You can get a replacement for that connector for about $3, if it's burned/fried. Another possibility is the start switch itself. Open the switch housing, and check it for loose wires and good contact, clean it, and put it back together. However, that usually is seen with pushing the start button, and nothing happens but the lights going out.
(((=-JammeR-=)))
'03 Spirit 750
Ride Bells by blue flames and shadowride69 (THANKS!!)
ABQ-Jammer is online now
post #5 of 16 (permalink) Old 05-17-2017, 03:37 PM
Gas tank vent wouldn't prevent the engine from turning over. This is an electrical issue.
jpr1968 is offline
post #6 of 16 (permalink) Old 05-17-2017, 06:32 PM
jwinker's Avatar
...unless he means the engine "turns over," but doesn't start...
There's no such thing as "Spare Time" or "Free Time" or "Down Time."
Time is time. All you have is "Life Time." GO.
-- Henry Rollins
jwinker is online now
post #7 of 16 (permalink) Old 05-17-2017, 08:00 PM Thread Starter
thanks for the reply! When I try to start her, there is no response at the engine. I mean the engine dosen't even try to start.
Last time this happened, it was with a freshly recharged battery. So may be the battery isn't being recharged while I'm riding?
idgeek is offline
post #8 of 16 (permalink) Old 05-17-2017, 08:01 PM Thread Starter
interesting...
Will try this next time!
idgeek is offline
post #9 of 16 (permalink) Old 05-17-2017, 08:07 PM Thread Starter
wow! thanks for the advices!
What do you mean by "3-yellow wires"?
idgeek is offline
post #10 of 16 (permalink) Old 05-17-2017, 08:08 PM Thread Starter
yes. that's what I am thinking. thanks.
idgeek is offline
