03 ACE Shifting Troubles - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 15 (permalink) Old 05-17-2017, 09:18 AM Thread Starter
Nuh_auni's Avatar
Ok gentlemen, let me start with, Forgive me my absence; been so dayum busy the last few months it's not even funny, but all is well (as promised @Moonrider I'm back).
But I have returned, and while I hate to jump back into the forum with a problem: I have a problem.
My 03 ACE Deluxe was shifting poorly, and now seems to not be shifting much at all.
I changed the oil about 3 weeks ago to start the season, took her out, and all was well.
Rode the next day and I had some trouble downshifting, I hit a hard bottom with shifter but the gear didnt drop. I found if I coasted for a bit, and pulled the shifter up it would then downshift as normal.
Next few rides I had the same problem, and it a couple times I had to pull over and rock forward to get the gears to cooperate (a problem I've had the whole time I've had Grace but not often, always going into first from neutral at a standstill)
That problem seemed to work itself out after 3 or 4 short rides, but then last night, about 11pm, on my way home from teaching a class and not but a 1/2 mile from the house, I could not get her to shift above 2nd no matter what I did, and this is the first time I've ever had trouble UP shifting.
Now My first thought was slack in the clutch cable, but it feels right at the lever, and I can cycle through 1 N 2 fine, so I fear I'm in deeper trouble.
Lend me your thoughts and expertise brothers, it's 78* already this morning and I had to take the truck to work.
Sometimes it seems like I'm arguing, that's just how I work out a solution:.. Other times I'm arguing.
'Grace' 03 Shadow Ace Deluxe VT750CDA
My Map or nuh-auni.tumblr.com
Nuh_auni is offline
post #2 of 15 (permalink) Old 05-17-2017, 11:17 AM
I would clean, inspect for damage or looseness and lube the shift linkage first.
jpr1968 is offline
post #3 of 15 (permalink) Old 05-17-2017, 11:42 AM
Scared's Avatar
Check clutch adjustment, if that looks good then pull the clutch and inspect and clean. That's where I'd start.
http://i997.photobucket.com/albums/a...C64070057F.jpg
2002 750 ACE DELUXE: Sold
2003 BMW K1200GT
Ride Bell by Old Dad
Ride Bell by Gnarly
Ride Cross by "Captain D"
Scared is online now
post #4 of 15 (permalink) Old 05-17-2017, 11:47 AM
swifty2014's Avatar
Have you ever tried shifting without the clutch after you get moving? I have tried a few times and it is very easy. Just relax pressure on the throttle and gears, and it will pop in up or down. I don't like to do it but it is good to know in case of a clutch failure. I only mention this to see if you can shift up without the clutch in this case. If not it must be an internal problem with the shift drums.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #5 of 15 (permalink) Old 05-17-2017, 12:12 PM Thread Starter
Nuh_auni's Avatar
https://www.youtube.com/watch?v=vq11CusULlk
I hard shift all the time, 3 of my cages are manual and I do it in them too, no response above 2nd that way either last night.
@jpr1968 @Scared
That'll be my first thing, but I have some fear that it may be something else, because it won't go when I hard shift like swifty suggested
Sent from my SM-G925P using Tapatalk
Nuh_auni is offline
post #6 of 15 (permalink) Old 05-17-2017, 12:35 PM
swifty2014's Avatar
If the shift lever moves normally but doesn't click into the gears it may be a shift selector problem and not internal with the gears. This video is an example, but your link is a different shape.
1983 750 Shadow
From the past=
post #7 of 15 (permalink) Old 05-17-2017, 12:36 PM Thread Starter
Nuh_auni's Avatar
https://www.youtube.com/watch?v=IF0kTTf1bgw
That sounds like what I felt, I'll watch the video at lunch
Nuh_auni is offline
post #8 of 15 (permalink) Old 05-17-2017, 12:44 PM
swifty2014's Avatar
Here is some more lunch time entertainment.
1983 750 Shadow
From the past=
post #9 of 15 (permalink) Old 05-17-2017, 12:45 PM
Scared's Avatar
A bent shifting fork comes to mind here.
2003 BMW K1200GT
Ride Bell by Gnarly
post #10 of 15 (permalink) Old 05-17-2017, 02:59 PM Thread Starter
Nuh_auni's Avatar
https://www.youtube.com/watch?v=gx5ImN5NuUs
Watched them both, that sure seems to fit the feel.
I'll take a look... and hopefully find the problem.
If not @Scared I'll keep going and check the fork, though I'm not sure how it would have bent, though I suppose it could be a leftover problem from PO finally manifesting.
Either way I'll update this thread for prosperity when I find the problem.
Nuh_auni is offline
