i have a 98 aero 1100 and i just sproted an oil leak it commin from the plug above the drain plug i can actually move the plug with my finger. my question is this is that a pressed in piece with an o-ring to hold it in place. or should i just silcone it and hope it holds. thanks
#3 (permalink) |
If it is, here's the quick-and-dirty patch to get you through for about 1,000 miles: http://adlowe.net/Motorcycle/Shadow_...Plug_Patch.pdf
#5 (permalink) |
I got the parts from http://www.hondaparts-direct.com/ for about $60 delivered to my door. IIRC, they were about $10 more from http://www.ronayers.com and both use the same part numbers listed in the repair instructions; http://www.bikebandit.com also lists them but with different part numbers and even more expensive than the other two.
