How to test a fuel pump on an 83 VT750 - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 7 (permalink) Old 06-24-2007, 06:52 PM Thread Starter
I have just purchased a non-running VT750. I have never had a bike with a fuel pump before, and I would like to know if it working. When there is power to the pump (using a jumper wire), it just clicks once - is it supposed to do that or is it supposed to keep on pumping?
Hairy Hobbit is offline
post #2 of 7 (permalink) Old 06-24-2007, 09:33 PM
downinit25i's Avatar
Send a message via AIM to downinit25i
I'm pretty sure that it tracks with engine speed. While the bike idles, it pumps once every few seconds. If you rev it up it will start pumping faster. Maybe it's not pumping because the ignition isn't going.
1985 VT 700 C
downinit25i is offline
post #3 of 7 (permalink) Old 06-25-2007, 12:57 PM Thread Starter
Thans for your reply. That gives me a better understanding of what to test. I will make sure that I am getting a pulse voltage to the pump.
post #4 of 7 (permalink) Old 06-26-2007, 02:58 AM
Pull a carb fuel hose and turn the ing. on, got gas running out the hose?? it's working. most elc. pumps without a internal by pass will shut off when the carb hose is pressurized to the out put pressure.
Ted
SHADOW 1100T is offline
post #5 of 7 (permalink) Old 06-26-2007, 08:32 AM
Re: How to test a fuel pump on an 83 VT750
In order to test it you need to build a wire with a diode in it to test ... It's in the clymer manual, but I don't have it with me ...
01 Kawasaki Vulcan VN750
83 Honda Shadow VT750c
KLank is offline
post #6 of 7 (permalink) Old 06-26-2007, 12:20 PM
That would make a lot of sense, I guess...
1985 VT 700 C
post #7 of 7 (permalink) Old 07-06-2007, 12:51 PM Thread Starter
It works. I ended up pulling a hose of a carb and cranking the motor. I got flow
