Slow speed turning 03 Shadow Ace Dlx. - Honda Shadow Forums : Shadow Motorcycle Forum
Old 09-03-2007, 08:07 AM   #1 (permalink)
Default Slow speed turning 03 Shadow Ace Dlx.
Hi all, Newbie here with questions ref slow speed turning. 2003 Shadow ACE Dlx. (Wife's Bike) I noticed that when turning right or left, the handle bars seem to get to a point that it suddenly drops off in direction of the turn. It takes some muscle to straighten it back up. Normal or should I check the fall-away of font wheel. Seems to ride just fine otherwise. I installed lowering kit on rear (2") otherwise stock. Did not notice if problem existed prior to lowering it. Suggestions would be appreciated.
PS I ride Harleys with little experience with Hondas.
Thanks, Bill
bgc912 is offline   Reply With Quote
Old 09-03-2007, 08:45 AM   #2 (permalink)
Wassup's Avatar
I have the exact same bike, and I don't recall seeing it do that. Are you talking about a full lock turn?
Wassup is offline   Reply With Quote
Old 09-03-2007, 11:35 AM   #3 (permalink)
Yes full lock turn, when about 2 thirds turn it just seems to fall to full and then it is a little harder to turn back to straight. Up until 2/3 it is smooth and normal. Bike purchased in July this year (07) with 4500 on spedo.
I guess I will remove the lowering kit and see if it is still there.
What do you recommend checking before I remove the lowering blocks.
Thanks again
Bill
Old 09-03-2007, 03:53 PM   #4 (permalink)
Wassup's Avatar
To be honest, I am not really sure what to tell you to check. Maybe one of the other techies will jump in. I took mine out for a "ride around the block", and checked it again, and I don't seem to see that happening.
Old 09-03-2007, 04:17 PM   #5 (permalink)
Hey thanks.
I can just sit on it and turn the handlebars either way, and at about the 2/3 point I can feel the front end kinda drop down. It takes some effort to turn it back to center and I can feel the front raise up. Neither of my Harleys (Classic or Sporster) do this. I lowered the rear about 2 inches and maybe it caused the center of gravity to change. I will talk to Honda Tuesday and/or remove the lowering blocks.
Thanks
Bill
Old 09-03-2007, 05:09 PM   #6 (permalink)
Send a message via Yahoo to blonodmc
yes remove the lowering blocks to see if it goes away, if it dosent , then raise the front end and check your tree bearing (the stearing bearings) to see of there sloppy or gritty if so , it might be time for new bearings, if not gritty then retourq to specs
ace disciples m/c
blonodmc is offline   Reply With Quote
Old 09-03-2007, 09:24 PM   #7 (permalink)
Follow UP.. Just contacted Scoot Works... They advised that this is normal when lowering rear only. They suggest I install the front lowering kit and this should take care of the proble.
Thanks for help
Bill
Old 09-04-2007, 08:11 AM   #8 (permalink)
Wassup's Avatar
I love it when a plan comes together. Good luck!
