86 vt700 fuse block - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 8 (permalink) Old 09-11-2007, 07:27 PM Thread Starter
86 vt700 fuse block
looking at the wiring diagram there are 7 fuses on the vt700.i have looked every where and cant find one fuse ,removed the pilot lights and still can't find them .can someone tell me where to look? thank you whiz630
on the 86 shadow carb there is a air cut off valve,what is it used for? and can it be removed?
whiz630 is offline
post #2 of 8 (permalink) Old 09-11-2007, 08:10 PM
XGrudge CityX's Avatar
Send a message via AIM to XGrudge CityX
In between your speedo and tach gages under the plastic. There should even be a diagram and a spare int there too, That is if the 86 is like my 85.
1985 VT700C !! PARTING OUT !!
XGrudge CityX is offline
post #3 of 8 (permalink) Old 09-11-2007, 09:35 PM
tubes_rock's Avatar
Nope, the 1986 is not like the 1983-1985 models. Sit on the bike, and turn the handlebars to the right. Now get off and look at the area under the speedometer, where the frame meets the forks. There's a plastic cover about 4 inches tall and an inch wide. That covers the fuses.
--Justin
Currently Running Stable:
2010 Honda NT700V
1986 Shadow 700
1987 Honda Rebel 450
1973 Honda Mini Trail 50
tubes_rock is offline
post #4 of 8 (permalink) Old 09-11-2007, 09:38 PM
Place bike on center stand, turn handle bars to far right & you should see a black box on left hand side right below the handle bars. Believe one screw at top holds cover on.
Reed
1986 VT700C (Bought new in 1989)
w4jz is offline
post #5 of 8 (permalink) Old 09-11-2007, 09:50 PM
damn I lose. just whn I thought I could help someone haha
post #6 of 8 (permalink) Old 09-11-2007, 09:56 PM
tubes_rock's Avatar
Oh, don't worry! There's lots of people here with the 1983-1985 models. Almost everything between those three years is the same, except that most of the 1984/1985 models are 700s and not 750s.
--Justin
2010 Honda NT700V
1986 Shadow 700
post #7 of 8 (permalink) Old 09-11-2007, 10:25 PM Thread Starter
fuse box
thank you guys for your help,i would have never found it. i own a 1985 vt 500,85 vt 700 and now 86 vt 700.and i think the 86 was one of a kind.seems like every thing on the bike is different. whiz630
whiz630 is offline
post #8 of 8 (permalink) Old 09-12-2007, 01:55 AM
Pictures of this one of a kind?
