I'm new here so please forgive me if this has been covered before.
I bought an '86 1100 about 2 months ago and was planning on making it a winter project, ( it came home in 5 different boxes) but things went a little faster than I thought they would. Truth is I couldn't leave my hands off it! I have 50 miles on it already and it's working well.... except for the fuel cut relay. I've had to bypass it to get the bike to run. I talked to the local dealer and he said that it would probably be OK but that it would more than likely shorten the life of the fuel pump. I was wondering if any one had any input on this. Will it be OK to run it like this? Does anybody know where I can find one? Or even find one that will adapt? Any help will be much appreciated! Thanks, Andy |
#2 (permalink) | |
The relay is there to stop the fuel pump if the engine stops running. With the relay bypassed, engine off and the key on, it could pump fuel into the engine and fill the crankcase or pump fuel onto the ground. Al |
#3 (permalink) |
That's what I thought as well. I just make sure I don't sit there with the key on. I tried to bypass it with the power from the thumb switch but it doesn't seem to work. It only works when I use the power from the ignition switch. I haven't quite figured that one out yet.
I suppose I could always wire a rocker switch or something similar to power the fuel pump, the ignition switch just seemed to be more simple. I just have to remember to un-hook the fuel pump if I'm working on anything that I need the key on for. |
#4 (permalink) | |
Is there any place where I can buy this relay? Or is there any other relay that fits to this bike? If I remember correctly the text in the relay is CF-324 so is there same kind of relay in any other bike?
My dad has the same bike with broken relay and refuses to just bypass it. Is it the only way? Quote:
If it has the feature it doesn`t matter even if I forget the power on, because the pump stays stalled? |
