Cause Of BackFire ??? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 15 (permalink) Old 01-15-2008, 12:35 PM Thread Starter
1moxxi1's Avatar
2000 Honda Shadow 750 ACE
10,000 miles
Sometimes after a downshift, I will get a backfire.
Other than that, the bike runs perfect.
What could be the cause for this?
I do not know when the last tune-up was done.
1moxxi1 is offline
post #2 of 15 (permalink) Old 01-15-2008, 12:37 PM
AngryHatter's Avatar
Lean running.
I usually use Chevron; when I get some gas at Shell, I invariably backfire once or twice.
It's not a problem unless it occurs constantly.
AngryHatter is offline
post #3 of 15 (permalink) Old 01-15-2008, 12:41 PM
Guest
It could also be a dirty air filter.
Spark plugs could be slightly fouled or dirty.
Spirit_1100 is offline
post #4 of 15 (permalink) Old 01-15-2008, 01:53 PM
post #5 of 15 (permalink) Old 01-15-2008, 04:23 PM
jrh_67's Avatar
Is it an actual backfire or is it just popping back, you know like snap crackle pop...
2007 vtx 1300
2002 Shadow Ace, Gone but not forgotten
Robert
jrh_67 is offline
post #6 of 15 (permalink) Old 01-15-2008, 10:23 PM
doc. orwell's Avatar
I don't think what I'm about to share is the cause of your backfiring but others reading this might find some insights into their problem with with this issue. Yesterday as I was riding my Ace it started sputtering and backfiring, it got so bad I had to pull over. I first checked the fuel by turning the valve to reserve as the engine acted as if the gas had ran out, no luck in that. I then gradually revved the engine and found if I did so slowly it would regain some power. I did this for a few minutes and then rode home sputtered and backfired all the way. My neighbors walked over as I pulled into the driveway, and offered advice. "sounds like bad gas....sounds like your plugs need'a changing" etc. I was not convinced. I shut the bike down for a few minutes and then tried to restart it, no luck. Now it would not turn over and the lights were dim. After explaining to one neighbor that it was impossible to "push start" a bike like this, I asked a him for a jump start. This brought the bike alive and running well as long as the jump cables were connected. Getting there I thought, I ran into the house for my Volt meter, and checked the battery. The Voltage ran 10.2 volts. I had lost a cell in the battery while riding along at 50mph. This surprised me in that the battery was two months old. I replaced the battery and the Ace has been running fine. I also ran some voltage checks to see if the bikes charging circuit was doing its job and that it was not overcharging, it was fine. Moral here is that there can be several things that cause backfiring, in this case it was a kaput battery.
1997 VT 1100 ACE
1979 CX 500 Deluxe
doc. orwell is offline
post #7 of 15 (permalink) Old 01-16-2008, 08:20 AM Thread Starter
1moxxi1's Avatar
It was more like a "pop" sound.
And it isn't every time I downshift, everyone other one or so.
Dirty air filter, as one member suggested?
1moxxi1 is offline
post #8 of 15 (permalink) Old 01-16-2008, 06:27 PM
Another source of popping can be an exhaust leak, check the nuts mounting the header pipes to the cylinders.
1997 VT 1100 ACE
1979 CX 500 Deluxe
post #9 of 15 (permalink) Old 01-16-2008, 06:42 PM
bike1962's Avatar
Mine was doing that too. Ran some seafoam through a couple of tanks and it went away.
bike1962 is offline
post #10 of 15 (permalink) Old 01-16-2008, 07:05 PM
gat803's Avatar
Excuse me will I hijack this thread for a moment.
I'm curious, what about this bike makes it impossible to push start?
I now return you to your regularly scheduled thread.
You woke me up, for this???
gat803 is offline
