Hard to start, very very hard - Honda Shadow Forums : Shadow Motorcycle Forum
Old 01-19-2008, 02:32 PM   #1 (permalink)
Default Hard to start, very very hard
Hello,
I am not mechanically inclined, so hopefully you can help me..
I just bought a 1996 Honda Shadow ACE from the local dealer. Being Winter I didnt take it on a test ride. Well the dealer swore to me, that it runs great just a LITTLE cold natured.
This thing is extremely hard to start, once it does it runs fine. But man getting it started is like pulling teeth.
What should I check and or do? Any suggestions?
Thans
mrdmevans is offline   Reply With Quote
Old 01-19-2008, 03:14 PM   #2 (permalink)
Hey All™,
Welcome to the world of carbs, fuel enrichment valves, and the Honda Shadow world. If you want a bike that will start in the cold, the Shadow isn't it.
Glen
1989 VT1100C
GlenRoberts is offline   Reply With Quote
Old 01-19-2008, 08:04 PM   #3 (permalink)
daver'84's Avatar
Easy Stuff:
-full choke no throttle when starting
-turn up the idle a bit
-make sure the enrichment valves are adjusted properly
Harder Stuff
-synch the carbs
-change the stock jetting
(formerly Daver84)
Dad - '01 VT1100C / '01 ST1100
Son - '84 VT750C / '06 VT750C
Daughter - '86 CMX450
GF - '99 VS1400 / '06 FJR1300
BUILT A BIGGER GARAGE!
daver'84 is offline   Reply With Quote
Old 01-19-2008, 08:25 PM   #4 (permalink)
tubes_rock's Avatar
Whatchutalkin'bout, Glen?
My Shadow starts without any problems at all down to 25 degrees. It would probably start colder than that, but I'm not much for riding down to any colder than that so I've never tried.
The key is to open the choke (fuel enricher) all the way, and give it just the slightest bit of throttle. If you think you didn't open the throttle at all, that's just about the right amount! Then push the starter button and hold it (but not for more than 5 or 6 seconds) it should be started just fine. If the engine catches and runs before those 5 or 6 seconds are up (likely it will!) let go of the button! You don't want to run your starter for more than 5 or 6 seconds straight because it overheats the starter and the battery. Let it sit for 15 seconds if you had to really crank on it before you crank again.
Seriously, if it doesn't start within 3 tries at 5 seconds per try, you'll want to find out what the problem is. It shouldn't be too hard to start in cold weather.
--Justin
2010 Honda NT700V
1986 Shadow 700
Old 01-19-2008, 09:42 PM   #5 (permalink)
Hey All™,
LOL, Shadows don't like cold weather. Just for the sake of asking, is yours kept inside, or outside?
Mine is an older bike, but everything I've had done to it to get it to actually start when it's below 40 degrees, it's basically a new bike once again. The list of what I've done for it to crank like it does is probably longer than mosts mods they done over a dozen years, if anyone has kept one that long. It'll crank now in temps I have NO desire to ride in, which is what I wanted.
Glen
1989 VT1100C
Old 01-19-2008, 11:07 PM   #6 (permalink)
glennc's Avatar
Send a message via Yahoo to glennc
I got a small heater fan and have a timer to turn it on a few minutes before I start it.
http://www.hondashadow.net/forum/vie...956&highlight=
2002 Honda Shadow Spirit 1100
American Legion Riders
Patroit Guard Riders
If you can read this- thank a teacher, If it's in English- thank a Veteran.
glennc is offline   Reply With Quote
Old 01-20-2008, 10:06 AM   #7 (permalink)
Others have given you the basic's to start the bike in cool/cold weather. But I think the choke cable (fuel enrichment) might not be adjusted properly or maybe sticking. This can lead to very hard starting.
If as others suggest...no carb sync has been done you should do it as well. This will ease starting as well.
Having the bike sitting outside is also a problem in cold temps. Especially IF you only ride the bike occasionally. Thick oil (good reason for syn. oil), cold temps, weak battery makes for a hard starting bike.
Bullzeyet
bullzeyet is offline   Reply With Quote
Old 01-20-2008, 01:41 PM   #8 (permalink)
Default Re: Hard to start, very very hard
Originally Posted by mrdmevans
Hello,
Thans
Hey All™,
I wasted my time typing out a real long, detailed post, hit submit, and it went into the WWW black hole. So, this is the short, non-detailed version.
Things I've checked, or had checked in no order.
Battery- I've decided to buy a new one once a year.
Stator- Had mine replaced.
R/R- Mine was fine.
Wires and connections- Unplug, clean and grease EVERY one.
Ground Wire- Same as above.
Kill Switch- Same as above.
ALL cables- Lube or replace.
Gas- Make sure it's good.
Oil- Consider Rotella T 10w50 Synthetic
Plugs/Wires- Check, or replace with hotter plugs.
Check Fuel Enrichment Valves- Set or replace choke cable.
Side Stand- Clean and grease sensor.
Carbs- Sync or adjust.
Air Filter- Clean or replace.
It might be one of these, or a combination of all of it. As I said, I did all of the above, and have no clue what REALLY made the biggest difference. If you do all this, and still won't start, you bought a summer time motorcycle.
Glen
1989 VT1100C
Old 01-20-2008, 03:01 PM   #9 (permalink)
Why? A battery should last 3, 4, or more years. Seems like a waste of $$$.
Just curious...
2001 Shadow ACE 750(sold) - 2006 Star Roadliner (with Strat kit)
Roadliner mileage log
shroomhead is offline   Reply With Quote
Old 01-20-2008, 04:14 PM   #10 (permalink)
Default Thanks
Thanks Daver'84 I went through your list adjusted the idol and enrichment valves and it started right up.
Originally Posted by daver'84
Easy Stuff:
Harder Stuff
-synch the carbs
