Netural light comes on when clutch is engaged?? 1996 1100 AC - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 13 (permalink) Old 05-16-2008, 09:56 PM Thread Starter
1996 1100 ACE Had a problem where bike engine would not turn over. Found the problem to be in the start button switch. However before that my repair manual lead me to check the start relay.....here's where the problem originated I think. I separated the plug from the relay and carelessly turned the plug around and tried to plug back in.....blew the 30 amp fuse. I replaced the fuse and everything works fine except the neutral light comes on every time the clutch is engaged no matter what gear I am in. Does not affect the way the bikes runs, just kind of strange that every time I change gears the neutral lights flashes as I use the clutch...also when shifting to neutral I have to "feel" for neutral because as long as the clutch is engaged the neutral light is on. Unfortunately my repair manual is lacking in the wiring department...any ideas?
Boys belong outdoors!
ncnative is offline
post #2 of 13 (permalink) Old 05-17-2008, 02:47 AM
This is interesting, you shouldn't have been able to get a elc. contact by reversing the plug, the way there designed it would seem impossible to do that and then to blow the 30amp main,,,,that just don't seem right, it takes a direct short to blow that one and there would have been some major sparking going on.
The natural light is just a simple switch that is triggered by the tranny to close when in netural so what your saying is that it's going on in the open position if I'm understanding you right which is impossible, it's conceivable that if you reversed the neutral light wires that it would work as designed and that isn't right, you've got a wiring problem some place else.
You need to go thru what you did and check everything looking for wires that may be worn thru, something that got disturbed when you were doing what ever you did,,,Boy,,,good luck on this one, let us know what you find out OK?
Ted
SHADOW 1100T is offline
post #3 of 13 (permalink) Old 05-17-2008, 10:30 AM Thread Starter
Netural light
Let me clarify that I the moment I put the plug in backwards I did get a spark and it blew the fuse immediately, in fact I never got the plug down on the connectors, as soon as it made contact the fuse blew. But once I replaced the fuse and put the plug in correctly the bike works fine, as I said the only difference now with the bike verses before is the neutral light comes on every time the clutch is engaged
ncnative is offline
post #4 of 13 (permalink) Old 05-17-2008, 11:28 AM
litnin's Avatar
Ok, just to clarify.
When you pull the clutch lever in, you are DIS-engaging the clutch.
When the clutch lever is out (normal resting position) the clutch is ENGAGED.
Which is actually happening, the light on with the lever out or the lever back?
litnin is offline
post #5 of 13 (permalink) Old 05-17-2008, 12:01 PM Thread Starter
Neutral light
You're correct, DIS-engaging is what I should have been saying, ie. light comes on when i squeeze the clutch handle towards the handlebars to shift. Light goes out when I release the clutch handle. I'm thinking maybe the clutch diode?
ncnative is offline
post #6 of 13 (permalink) Old 05-18-2008, 01:54 AM
litnin's Avatar
Re: Neutral light
Yep, that's exactly what it sounds like.
Just looked at the schematic and it appears that it would do exactly
that if the diode allowed current in both directions.
litnin is offline
post #7 of 13 (permalink) Old 05-18-2008, 08:42 PM Thread Starter
Neutral light
Thanks, i will post what I find here.
ncnative is offline
post #8 of 13 (permalink) Old 05-23-2008, 03:33 PM Thread Starter
Neutral switch light
Yep, it was the 2 prong clutch diode. Honda dealer wanted $16.00 for one. I had some barrel shaped diodes with a lead on each end, i just shortened the leads and bent them to fit into the sockets the prongs of the old diode fit and it works fine.....basically $0.00 cost to repair.
ncnative is offline
post #9 of 13 (permalink) Old 07-14-2009, 11:16 PM
Re: Neutral switch light
[I tried PMing this, but it keeps sending the messsage to me instead of ncnative]
Hi there - in the post above, you said that instead of spending a lot on an official replacement diode, you wired in a regular barrel-shaped diode.
The clutch diode on my 1983 VT500C is toast, and I'd much prefer to do what you did than spend $20 on a tiny component. Could you please tell me how I can work out what kind of diode to get instead from a components store?
Thanks!
[btw. mine is a technically a S3H-02 silicone rectifier, if that means anything, part # 31700-124-003 (replaces 31700-124-00; I couldn't find a schematic for your 1996 1100 ACE, but there was one for the VT1100, and that bike uses the same part - so it's likely that I could use the same kind of makeshift diode that you did].
SpiceRack is offline
post #10 of 13 (permalink) Old 07-15-2009, 03:29 AM
Any 1N4001, 1N4004 will work fine.
Radio Shack has em or you can order at mouser.com for pennies each...
ivirscar is offline
