87 VT700 Shadow - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 10 (permalink) Old 06-01-2008, 09:15 PM Thread Starter
87 VT700 Shadow
New to the forum. I bought this 87 shadow that did not run real good between 3000 and 5000 rpm. I was convinced that the carbs needed cleanig since it only had 10000 miles on it. So I took the carbs apart and cleaned them and the problem is still there. It will scream if I stay on it all the way to red line, but I can not put it in overdrive at 60 mph because it acts like it has run out of gas. I have to keep the rpm's up and still sputters a little then (above 5000rpm). The fuel pump seems to be working. Any help? Thanks
mvorwerk is offline
post #2 of 10 (permalink) Old 06-02-2008, 09:02 AM
tubes_rock's Avatar
Welcome to the group!
I have the 1986 model of your bike, which is pretty much the same. It sounds to me like your carb slides aren't sliding enough. When you had them apart, were the diaphragms in good shape? No pinholes or anything?
Mine had a bit of hesitation around the range you're talking about, but nowhere near as severe. I put two #6 brass flat washers under each jet needle, and that got rid of it.
But for what you're experiencing, I think you have an altogether different problem. I'd be making sure those slides slide freely, and return freely.
Also, run it for 20 seconds at the point where it's hesitating, pull in the clutch, kill the engine, coast to the side of the road. After the engine cools for 20 minutes or so (important so you don't strip the heads!) pull a spark plug from each cylinder. Then you'll know if you're too lean or too rich.
Also, how's your fuel filter look?
--Justin
Currently Running Stable:
2010 Honda NT700V
1986 Shadow 700
1987 Honda Rebel 450
1973 Honda Mini Trail 50
tubes_rock is offline
post #3 of 10 (permalink) Old 06-02-2008, 07:58 PM Thread Starter
Fuel filter is fine. Carb looked great when I took it apart. Fuel pump pressure is about 3 lbs. Pump is pumping plenty of fuel. Cleaned and blew out everything in the carb. This has me stumped.
mvorwerk is offline
post #4 of 10 (permalink) Old 06-02-2008, 08:43 PM
tubes_rock's Avatar
If you measured the fuel pressure, then I'm going to assume that you're quite savvy mechanically, so forgive me for asking the following dumb question: when you're accelerating, is it running on both cylinders?
--Justin
2010 Honda NT700V
1986 Shadow 700
post #5 of 10 (permalink) Old 06-02-2008, 08:58 PM Thread Starter
Good question. I thought of that but the bike will scream if I stay on it all the way to 8000 rpm and never misses a beat. It only dies down between 3000 and 5000 rpm and trying to stay at a steady speed.
mvorwerk is offline
post #6 of 10 (permalink) Old 06-02-2008, 11:24 PM
tubes_rock's Avatar
3,000 - 5,000 RPM, at a steady speed, on level ground is probably about 1/4 throttle. That's pilot jet territory. Makes me wonder if the pilot jets are clogged (or maybe just one cylinder's pilot jet!). Those are the #41 or #42 jets that are in there. In my carbs, those took a whole to come clean. I thought they were clean, but under magnification, I could see that the orifice was half-moon shaped, so I cleaned them again, and they ended up round, like they should be.
I know what a bear those carbs are to get off, so maybe some Seafoam could save you the trouble of looking? (Then again, maybe not!)
This one has me wondering...!
--Justin
2010 Honda NT700V
1986 Shadow 700
post #7 of 10 (permalink) Old 06-03-2008, 08:50 PM Thread Starter
Seafoam was put in first thinking that might do the job. The jets were perfect. I am going to the Honda dealer in the next couple days and see what they think. I will keep you posted.
mvorwerk is offline
post #8 of 10 (permalink) Old 01-11-2017, 11:58 AM
EdK
BUMP -
Did this ever get solved? I'm having same issue
EdK is offline
post #9 of 10 (permalink) Old 01-12-2017, 09:16 AM
Ramie's Avatar
Originally Posted by EdK View Post
BUMP -
Read through this and see if it answers some questions.
CV Carb Tuning Procedures
If you still have problems start a new thread and give as much information as you can.
1998 Valkyrie Standard
2001 Valkyrie I/S
Ramie is offline
post #10 of 10 (permalink) Old 01-12-2017, 04:06 PM
The OP hasn't been on here since this post in 2008.
jpr1968 is offline
