If it's happening after the engine warms up, it's most likely either a problem with the ignition coils or the reluctors (small coils) under the clutch that triggers the ignition. If it runs fine cold, one of the coils probably has a broken wire that opens up once the coil expands from heat.
1984 Honda VT700C Shadow |
#4 (permalink) |
The honda manaul will give the specs to check it with a meter takes about 1min. I do not remember the spec but had to replace mine. If you do try to find a used engine cheap bought one for 40.00 The generator is about 250.00
#5 (permalink) |
i checked my pulse generator, and it checked out bad. 1 side was good and the other was bad. found a new one on bikebandits.com for 90 bucks plus the gasket for 10. im ordering it now and hopefully ill be back on the road wednesday afternoon. thanks for your help
