84 shadow vt700, what is ? - Honda Shadow Forums : Shadow Motorcycle Forum
Old 07-22-2008, 01:58 PM   #1 (permalink)
Default 84 shadow vt700, what is ?
on the "dash board" there is 3 red lights, what is the one in the middle ?
Loic is offline   Reply With Quote
Old 07-22-2008, 02:38 PM   #2 (permalink)
tubes_rock's Avatar
Three red lights? My bike's instrument cluster is arranged differently than yours, but the three red lights I have are "Low Oil Pressure," "Low Fuel" and "Tail Light Out"
--Justin
2010 Honda NT700V
1986 Shadow 700
Old 07-22-2008, 02:47 PM   #3 (permalink)
--Justin
so the middle one would be low fuel ?
Old 07-22-2008, 02:49 PM   #4 (permalink)
it's just because it started flashing the other day while I was teaching my wife to ride on a parking lot, and we did run out of gas.... (never happened before...) but since then the light still going on and off all the time ..
Old 07-22-2008, 03:40 PM   #5 (permalink)
tubes_rock's Avatar
Yeah, I guess process of elimination would make it the one light of those three that you can't identify.
It comes on when the main tank is empty, and the reserve tank is all that's left. It will flicker a bit as the fuel is around the trigger point for it as the fuel sloshes and activates it and then sloshes again and de-activates it.
It will light for 2 seconds as you turn the ignition on to serve as a bulb-check for the rider.
The sensor is pretty solid, but has been known to fail occasionally. That might also cause your flickering.
--Justin
2010 Honda NT700V
1986 Shadow 700
Old 07-22-2008, 03:42 PM   #6 (permalink)
squidchief's Avatar
on my 84 VT700C the three red lights in the middle of the light cluster are from L-R: low oil, brake light, low fuel. The only one I have ever had come on is the low fuel light and it is a solid light, not flickering or flashing. If your middle light was flashing, that's telling you there is a problem with your tail light. Quite possibly your low fuel light is not working. Bike Bandit and Hondaparts-direct both carry those little bulbs and it's worth having a couple of them handy IMO.
HAFND!!
squidchief is offline   Reply With Quote
Old 07-22-2008, 05:24 PM   #7 (permalink)
i'll check the tail light to make sure, but since this started since the bike ran out of gas i'm thinking about low fuel warning light. i bought a couple of bulb at checker auto a couple weeks ago, i was missing 3 bulbs.. i didn't want to get them from bikebandit because the shipping would have been more expensive than the bulb...
thanks for your help !
Old 07-22-2008, 11:02 PM   #8 (permalink)
I have an 84 VT700C as well, here is mine:
landon is offline   Reply With Quote
Old 07-23-2008, 08:19 AM   #9 (permalink)
tubes_rock's Avatar
Wow. A picture is certainly worth 1000 words! Nice!
--Justin
2010 Honda NT700V
1986 Shadow 700
Old 07-23-2008, 09:03 AM   #10 (permalink)
it look so new !!! the one I have, all the letters are gone....
from this pic it look like the tail would be the culpid, did I cross some wire last time I took it apart.... cuz really the first time that light went on I ran out of gas..... I guess I'll have to check my wire tonight.
