there are a lot of threads on changing tires.which brands to use, how long they should last, how much they should cost.etc. but i never see anyone mention anything about the innertubes. i just assume everyone just reuses the old tube but is there a lifespan to these tubes and what should you look for when inspecting the old tube.
#2 (permalink) | |
Super Moderator
With that said, when installing new tires, new tubes are in order too. I wouldn't even think of re-using an old tube. The tube is probably the weakest link; why take a chance with your life? Phil
![]() 1973 Yamaha RD-350 ![]() Sterling Heights, Michigan |
#3 (permalink) | ||
+1 they only cost a few dollars.
Shadow Kat 2001 750 Shadow ACE It is the honor & duty of the strong to protect the weak. |
#4 (permalink) | |||
#5 (permalink) |
I've reused them, "IF" they look good, no crap inside the rim, like rust etc. I wouldn't go more than 2 or 3 tire changes though. They get old and dry rot just like anything made of rubber.
1996 VT1100C2 ACE |
#6 (permalink) | |
#9 (permalink) |
Super Moderator
Front inner tube, 100-90/19, $22.91 at Ronayers.com. Lots of tire dealers will give you a good price if you buy them with a set of tires.
It's a lot of work (or labor) to remove the wheels for tires, the labor on the tubes is nearly nothing if done with the tires. Full labor charges again to go back and replace a tube later. Just makes sense, and cents, to me to replace it with the tires. CB |
#10 (permalink) | |
Super Moderator
Motorcycle tubes should only set you back about $15 or $20 at the most. The rear might be a bit more expensive because of the 90 degree valve stem. http://www.bikebandit.com/tubes/c/a642338a640036 For that price, I don't know why anyone would even think of re-using one. It's all there is between you and the road........... Phil
