Question for Gonzo - Honda Shadow Forums : Shadow Motorcycle Forum
Old 08-31-2008, 07:04 PM   #1 (permalink)
5644's Avatar
Default Question for Gonzo
I went to your website for the VTX Headlight Upgrade and really like the results!
The question I have is:
Do you think this would work for my 93 1100 Spirit?
It looks to me like it would bolt on just as easy for me as it did for you. I just thought I would ask to be sure before I spend the money.
1993 VT1100C Spirit
5644 is offline   Reply With Quote
Old 08-31-2008, 08:35 PM   #2 (permalink)
Gonzo's Avatar
I haven't looked at the early models upclose, but as long as the measurements of the mounting bolts match my website I would have to say absolutely.
Good luck,
Gonz
When does it end? It doesn't....it's a Vicious Cycle!!
Gonzo is offline   Reply With Quote
Old 09-01-2008, 01:32 AM   #3 (permalink)
5644's Avatar
Default Not Sure
After looking at the OEM micro fiche online, I'm sure the mounting bracket on my 93 is not the same as whats on your bike - but after compairing the two on your upgrade website it looks like they are very close. It looks like the bracket on my bike might be just a little taller and lean a little more forward.
On the same token there is quite a difference between the 02 Spirit and VTX brackets.
Any idea where I would be able to find the actual dimensions of these brackets using Honda's parts numbers? I'd like to find the bolt spacing where the light mounts to the bracket, and the width of the bracket in the same place.
I think it will work, but I would like to have a little more info to convince me before I jump into it.
Thanks for the help. And thanks for the great info on your website Condor! It sure did get the juices flowing.
1993 VT1100C Spirit
