Can't start bike without choke up full, can't cold or hot? - Honda Shadow Forums : Shadow Motorcycle Forum
Old 10-22-2008, 02:49 PM   #1 (permalink)
Default Can't start bike without choke up full, can't cold or hot?
I am wondering if it's normal for me to not be able to start my bike at all without have the choke all the up or on....and it's doesn't matter if it's cold or hot, if I try in the morning, or afternoon...what could be the problem, I believe it's warm outside, I should not have to start with choke correct?
93' Honda Shadow VT1100c
Hey, you were all beginners once too, so don't make fun of me, haha...I will post a lot of dumb questions on the forum, so just help me out, thanks
shadowvt1100c is offline   Reply With Quote
Old 10-22-2008, 03:00 PM   #2 (permalink)
Default Re: Can't start bike without choke up full, can't cold or ho
Warm start means the engine is still warm from running. A cold engine is one that hasn't been run in 'n' hours and cooled to ambient temps or close - regardless of how hot the day.
So, no you will not be able to start a 'cold' engine without choking it".
There are some caveats - like after I rejetted mine would start with no choke at 60F or above most of the time, and needs very little choke even on cold days.
Prior to jetting it would only start unchoked if the engine was still fairly warm from running.
Cbjr is offline   Reply With Quote
Old 10-22-2008, 04:38 PM   #3 (permalink)
Default thanks man
thank u very much, helps a lot....yeah I just got slip on, when I get full exhaust system, I will rejet and see if it makes a difference ....thanks for reply
