two wire turn signals - Honda Shadow Forums : Shadow Motorcycle Forum
Old 10-28-2008, 10:41 AM   #1 (permalink)
gab
Default two wire turn signals
Looks like I am keeping the 2 wire turn sigs I bought. Problem is I have 3 wire lighting. Can anyone explain how to make these both a running light and blinker?
gab is offline   Reply With Quote
Old 10-28-2008, 11:05 AM   #2 (permalink)
Guest
the solution will involve diodes, a resistor and a bit of wiring...this post covers some of the information...
http://www.hondashadow.net/forum/vie...224&highlight=
You will need to put the resistor on the running light circuit (along with a diode) to reduce the voltage level to the light to dim it. Tie the running lights together and split off to each signal light.
The turn signal circuit will only get a diode. The turn signals will have to remain separate.
You can use these diodes: 3A diodes (Radio Shack 276-1144).
Hope this helps.
Joe
Spirit_1100 is offline   Reply With Quote
Old 10-28-2008, 09:03 PM   #3 (permalink)
O'Larry's Avatar
Send a message via MSN to O'Larry Send a message via Yahoo to O'Larry
The easiest way is to go to the autoparts store and pick up a couple of new dual pin contacts/pigtails that will go into the sockets of the lights you now have. You will have to use the T 1176 type bulbs. You will then have your three wire system.
O'Larry
Ride Bell by Kara-MIA BELL by Bear
'04' Black Flame Sabre
O'Larry is offline   Reply With Quote
Old 10-29-2008, 06:18 PM   #4 (permalink)
What type of light did you buy? LED or just a different look?
nrburkett is offline   Reply With Quote
