Yellow Stator Wire - Honda Shadow Forums : Shadow Motorcycle Forum
Old 12-02-2008, 10:35 AM   #1 (permalink)
Default Yellow Stator Wire
I have a 2003 Sabre 1100. From learning from you on this site, I found that my connector from the stator was burnt with 1 yellow wire disconnected. Please tell me if that wire would cause any difference in the way the engine would run.
Also, can someone tell me which is my #1 cylinder.
Thank you!!
pastor
Pastor is offline   Reply With Quote
Old 12-02-2008, 12:17 PM   #2 (permalink)
The 3 yellow wires do not affect how the bike runs per se BUT does affect how well your battery stays charged eventually affecting it ability to run. The three wires produce AC voltage to the rectifier which in turns produces the 12+ volts for you electrical system. If one wire is disconnected , you will be push starting it soon and replacing a battery unless the problem is corrected. Check your voltage to the battery at about 3000 RPM, it will be less than 13.2 Volts, and your battery is dying. You will be stranded soon.
2002 Sabre - 2005 Rebel
1985 Magna 750
1984 Shadow 700
Capital City Riders
Tallahassee, Fl
N4AME
Bill Fuller
bfuller9999 is offline   Reply With Quote
Old 12-02-2008, 12:36 PM   #3 (permalink)
Just a follow up on my last post. Your #1 cylinder is the REAR cylinder. I would definently get rid of the connector. Simply solder the wires instead of using the connector. Before soldering the wires, check the voltage output of the stator. Number the wires 1 -2 - 3. Check the voltage at 1-2, 1-3, and 2-3. Set your meter for AC VOLTAGE. The reading should be the same for all readings.
1985 Magna 750
1984 Shadow 700
Capital City Riders
Tallahassee, Fl
N4AME
Bill Fuller
Old 12-05-2008, 02:25 AM   #4 (permalink)
Or you can take your VOM with it set on resistance, put black to ground and touch the 3 yellow wires, if you get a reading on any of the 3 the stator is no good.
You can also use a powered line tester with a light and doing the above if the light comes on
When you solder the wires, and you really want to do that, it makes NO difference which yellow wire goes to which yellow wire.
Anybody that has a Honda needs to solder the yellow wires and it makes NO difference which model you have,,,do it,,,,it a weak point.
Ted
Old 07-01-2009, 04:46 PM   #5 (permalink)
I just reread this bookmark and saw that I did not thank you for your replies. Thank you very much and I am sorry I didn't do this a while back. I really appreciate the help I receive from HSN.
John
Old 07-02-2009, 10:33 PM   #6 (permalink)
The infamous stator connector plug strikes again! Keep an eye on ALL of those cheap plugs. They make it easy to assemble a bike for the factory but they don't last long in the real world.
A 9m is a .45 set on stun
Drail is offline   Reply With Quote
Old 07-03-2009, 08:57 AM   #7 (permalink)
Where do I find this stator wire connector of which you speak; I'd like to solder the wires if I can find it. Jon
jon lewis is offline   Reply With Quote
Old 07-03-2009, 10:38 AM   #8 (permalink)
On my 84 VT700C it is located in a bracket that is mounted right in front of the battery, mine had never been fixed the wire ends right at the male/female spade connectors were slightly black and the plastic around the male/female spade connectors was melted and had been for some time.
To make mine easier to work on in the future I chopped the plastic plugs off and soldered new connectors onto the wires and heat shrinked them instead of soldering them directly together.
landon is offline   Reply With Quote
Old 07-03-2009, 11:42 AM   #9 (permalink)
One thing that makes it easy is that the stator wires are the only solid yellow wires on the bike when you solder them it makes no difference which yellow wire goes to what yellow wire.
Ted
Old 07-03-2009, 06:48 PM   #10 (permalink)
Do you suppose that's where I'll find it on a 98vt1100c? Jon
