Connecting 12v Cigarette Lighter to Shadow Spirit Battery - Honda Shadow Forums : Shadow Motorcycle Forum
Old 12-17-2008, 05:20 AM   #1 (permalink)
Default Connecting 12v Cigarette Lighter to Shadow Spirit Battery
Hello. I recently was given a Garmin Nuvi 780 GPS, which I will be using with my 2003 Shadow Spirit VT750DC. This GPS is designed for cars and not bikes, and thus many of its key features are housed in a device that must be plugged into a car's 12v cigarette lighter.
I have read elsewhere that it's possible to connect a cigarette lighter outlet to the motorcycle battery, via the pigtail cords of a battery tender. I've purchased a device that will connect, on one end, to the pigtail cord, and that provides a 12v cigarette lighter outlet on its other end.
Only problem is that I don't have a battery tender, and I know virtually knowing about electrics. The budget battery tender on Amazon (deltran jr. model) is rated at 750mA, or .75 amps. I was wondering if this will provide adequate power for the purposes of sending power to my GPS, or if I'm going to need a battery tender with a higher amp rating.
Thanks,
Todd
ToddSpirit is offline   Reply With Quote
Old 12-17-2008, 09:41 AM   #2 (permalink)
Steve-O's Avatar
750 ma is fine. That's what is on my bike. It's a no brainer to connect. Positive to positive. Should screw down on your battery. Just wind the dongle down through the frame on the left side. The BTJ is a trickle charger. It's made to keep the battery charged, not charge a dead battery.
I think you probably got the power adapter from bohemian biker
http://www.bohemianbiker.com/products.htm
That's what I have too. Great little device for adding a power adapter when you need one. I use it to charge my cell phone when I'm on long rides on my bike...as I use my cell phone to listen to music as I ride.
2009 Stratoliner (mine), 2008 Stratoliner (hers), 2010 Harley Rocker, 2002 Honda VLX
Steve-O
Steve-O is offline   Reply With Quote
Old 12-17-2008, 10:08 AM   #3 (permalink)
fish and teach's Avatar
Check this thread out.
http://www.hondashadow.net/forum/viewtopic.php?t=70539
fish and teach is offline   Reply With Quote
Old 12-17-2008, 05:14 PM   #4 (permalink)
wibadgervbfan's Avatar
boy, for 7 bucks, I may just have to pick up that connection
2006 Shadow Spirit 750DC
Ride bell by Kara, Willie & Max saddlebags
Billski taillight, cheapo light bar
CRAP reservoir cover
wibadgervbfan is offline   Reply With Quote
Old 12-18-2008, 02:15 AM   #5 (permalink)
Make sure you fuse the hot (red) side if you hook it to the battery.
Ted
Old 12-21-2008, 10:39 PM   #6 (permalink)
Steve-O's Avatar
I took a long trip this weekend. Used the bohemian to connect to my battery tender dongle. Used this combo to charge my cell phone with a cigarette style charger. Worked like a charm. Charged my phone in about 30 minutes .... bike started fine too! It's a great extension if you don't want to permenantly install a cigarette power adapter AND if you alread have a battery tender dongle.
Steve-O
