coolant leak - Honda Shadow Forums : Shadow Motorcycle Forum
Old 04-11-2009, 03:59 PM   #1 (permalink)
Default coolant leak
Hi all,
I have a coolant leak on my Tourer. I thought at first that it was from the tube that connects the two heads. I now think it's from a seam in the head itself. Is this possible? How big a deal is it if so? Any help would be great. Thanks!
Casey
99 Shadow ACE Tourer
ender is offline   Reply With Quote
Old 04-12-2009, 05:50 PM   #2 (permalink)
bump
and Happy Easter!
Old 04-12-2009, 11:07 PM   #3 (permalink)
Bubba1954's Avatar
If in doubt about the prognosis, take the bike to another doctor for a second opinion.
Shannon Koehn (AKA) Bubba1954
email skoehn@cox.net
'Life's tough......it's even tougher if you're stupid.' -- John Wayne
Bubba1954 is offline   Reply With Quote
Old 04-13-2009, 01:19 AM   #4 (permalink)
If it is leaking from the head area then it must be the head gasket which would be unusual, try tighten the head bolts then keeping the bike upright run it untill the fan comes on and then check where it's coming from it tightening the bolts didn't do the trick,,,,,,,,,love that color combo
Ted
Old 04-13-2009, 09:52 AM   #5 (permalink)
I also have a coolant leak. It is coming from somewhere under the backbone, but I can't figure it put with the gas tank on. I looked into getting a colling system pressure tester, but the best deal I could find was $70. I can't get an auxillary shop gas tank for any cheaper. This is my first liquid cooled bike and there are a lot more parts to the cooling system than I would like. Any suggestions as to where I can get a cheap pressure test or if it is even worth it? I worry about hanging my custom painted gas tank up and running a gas line.
Just ride
Rob Walker is offline   Reply With Quote
Old 04-15-2009, 12:24 PM   #6 (permalink)
Thanks. Is tightening the bolts something I can do? Where would I find them? Thanks again.
Old 04-15-2009, 08:08 PM   #7 (permalink)
Go here and look up your bike and find the heads, you will see wheer there at and yes you can do it.
http://fiche.ronayers.com/Index.cfm
Ted
