Running Rich - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 10 (permalink) Old 04-13-2009, 04:16 PM Thread Starter
Running Rich
Ok i am new at fixing bikes. I have a question first I have an 1985 vt700c that is running rich to the point that the plugs carbon up so much in less than 30 min to the point it shuts down the bike. Thanks for the help Ray
the85th is offline
post #2 of 10 (permalink) Old 04-13-2009, 04:51 PM
Check air supply - filter clogged - vemin nests etc stopping air flow.
Then check the enrichment valves(choke) see if they cable free-play is adeqate to turn off the choke.
Cbjr is offline
post #3 of 10 (permalink) Old 04-13-2009, 06:16 PM Thread Starter
ok i have checked the air and no critters. could you explain how to check and adjust the choke the manual i have is king of vague on how to do it thanks again. Ray
the85th is offline
post #4 of 10 (permalink) Old 04-13-2009, 09:18 PM
Take a look at the assembly #8 that will be the termination point of the choke/enrichment valve assembly.
Click Here
How this works is:
You pull the choke lever the cable pulls a needle valve out of the hole and enrichen the circuit instead of blocking the air.
In order for the valve to close the cable has to be free enough and have enough slack to allow the little spring to push the valve closed.
If you look at the cable labeled #13 the un-numbered cable next to it shows a good example of the enrichment assembly. There is a 14mm nut like cap that is removed and the whole assembly pulls out (watch out for the small spring needle and any other parts to fall out-they are easy to reassemble and easy to lose -put the parts in a small bags and don't mix up the needles). The amount of free play should be noted in your manual - and the cable should move freely.
Move the handlebars lock to lock and watch the cable for movement as well, measure the shortest length from cable end to outer sheath with the choke lever off.
Hope that is clear - it's pretty obvious when you get a wrench on it and see what is going on.
Cbjr is offline
post #5 of 10 (permalink) Old 04-13-2009, 10:52 PM
radarwill's Avatar
+1
radarwill is offline
post #6 of 10 (permalink) Old 04-14-2009, 04:51 PM Thread Starter
ok tried the adjustment and when i loosened the cable at the handle there was only about 2-3 mm of space how much should it move.
the85th is offline
post #7 of 10 (permalink) Old 04-14-2009, 11:30 PM
If I had only known about ronayers!
'97 Shadow ACE VT1100C2V
bigpigtx is offline
post #8 of 10 (permalink) Old 04-15-2009, 08:36 PM Thread Starter
ok new question i measured the primary side of the coil and it measured 3.3 ohms and the service manual shows it should be 2 ohms could this be causing the problem of not all the fuel burning and the plugs carboning up? When i took a plug out and laid it next to the head all i got was a weak yellow spark. Thanks for any help Ray
the85th is offline
post #9 of 10 (permalink) Old 04-22-2009, 04:12 PM Thread Starter
Still need help
Ok i pulled the carbs off and there seems to be the stock jets in it they have the #120 stamped on them. the floats look good no cracks the needle and seat look like they are new. Could there be something that i am missing. the carbs look nice and shinny. How stiff should the spring in the slides be. mine are kinda weak. Thank you for any help. Ray
the85th is offline
post #10 of 10 (permalink) Old 04-22-2009, 09:10 PM
You could check for a weak spark by sticking the business end of the spark plug on the tip of your tongue then get someone to try to start the bike! If you **** and piss at the same time the plug is good.... If you just piss or **** or even just twitch uncontrollably then itís a weak spark and change the plug first then the coils!
I kid, I kid
seriously tho.
My first thought wouldve been the choke!! i cant help a whole lot with this sorry! Just check the funcition of the choke and look at the cable that operates the choke.
Jason
95 1100
salt17 is offline
