fuse questions - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 8 (permalink) Old 04-29-2009, 11:39 AM Thread Starter
fuse questions
my turn signals, brake light, nueutral light, and horn are not working i am assuming this is a fuse issue because they all quit at once. my question is where are the fuses at, under the tank? does it use fusable links and if it does use a fuse are they regular automotive fuses. thanks for the help, oh yeah the bike is a 96 1100 ace
slowc10 is offline
post #2 of 8 (permalink) Old 04-29-2009, 11:46 AM
Shandley's Avatar
Re: fuse questions
I am unsure of the 1100 ace but most every bike I have done electrical work on has the fuse box under the seat. This picture is taken from a 2005 Aero service manual. I think this is your best bet.
Thanks,
Shandley.
2004 Honda Shadow Aero VT750C: Punched exhaust.
2005 Honda VTX 1300S: DG Hardchrome, American Classic straight pipes, Backrest, Barons tach, Cobra Light Bar, Triple Whammy lamps, Cobra Passenger & Front Floorboards, K&N air filter, Willie & Max saddlebags, Mustang wide saddle touring seat
Shandley is offline
post #3 of 8 (permalink) Old 04-29-2009, 01:50 PM
If you have the room, use a circuit breaker with the same amp rating.
Old Wild Bill is offline
post #4 of 8 (permalink) Old 04-29-2009, 01:57 PM
lphernan's Avatar
it looks like the fuse box may be accessible from a side cover. on my 02 Sabre, the fuse box is behind the left side cover by the battery.
02 VT1100 Sabre
Green to Copper Kameleon
URL]
lphernan is offline
post #5 of 8 (permalink) Old 04-29-2009, 02:43 PM
litnin's Avatar
On the ACE, the fuse box is on the left hand side of the bike.
If you look at the side cover that has the battery behind it, move
back towards the backend of the bike.
There is a little black plastic cover.
It has a screw in the upper left corner and middle right side.
Remove that cover and the fuses are under it.
litnin is offline
post #6 of 8 (permalink) Old 04-29-2009, 02:51 PM
JN
JN's Avatar
Located by the passenger peg on my VT1100 Spirit I have to put the peg down to unscrew it.
1997 VT1100C HondaShadowSpirit(Daily Driver)
1978 Honda xl125(Ranch Rider)
JN is offline
post #7 of 8 (permalink) Old 04-29-2009, 04:13 PM
litnin's Avatar
Yep, that's it.
If you have floorboards, I've generally had to completely remove the
floorboards to get the screwdriver in there.
litnin is offline
post #8 of 8 (permalink) Old 04-30-2009, 12:23 AM Thread Starter
found it, yep blown fuse everything is working fine now, thanks for all the help
slowc10 is offline
