I've had this '01 750ACE for three years now and recently I find the front end bottoming out at railroad tracks and certian intersections that have pretty decent ruts... Does this mean that I am in need of new seals or more oil or both. This is a new issue for me and any links or advice on this topic would be very much appreciated. Dan.
In order to do it right the first time....OVER do it! |
#3 (permalink) |
The springs do get weaker over time - however for about $60 and a quart of heavier wt fork oil you can make vast improvements to the front suspension - which by design is pretty mushy.
Buy a set of Progressive Springs from Progressive Suspension, replace the current fork oil with Belray 15wt - created a nice front suspension feel. Fork seals don't need to be replaced unless they are leaking and won't need to be touched to do the spring/oil change-over. |
#4 (permalink) | |
![]() ![]() 06' 1100 Spirit 71' CL 100 99' Valkyrie Ride Bell by "Yoman" |
#5 (permalink) |
OK, no leakage=good seals...got it. After reviewing the manual, my next question is, can the fork oil be added/replaced with out dismantling the fork itself? The reason I ask is the bike is my only mode of transportation and I need to make sure this procedure can be accomplished in an afternoon or a day topps. Also the manual specifies 8-10wt oil, will 15wt oil work properly? If anybody knows of any sites that demonstrates the process, that would also be great. Thanks for tips so far (keep 'em comming please).
#6 (permalink) |
Someone mentioned this in an earlier thread, and I don't remember who it was but it was a very good reminder.
Make sure you keep your fork tubes clean. A dried bug on your fork tube can cause cuts in your fork seals.
'98 Shadow 1100 ACE
#7 (permalink) | |
go ahead and do a complete rebuild. Chances are, if the oil needs changed, the guide bushings do to... The oil in the forks don't wear out... it gets contaiminated... by wear from the bushings. You can do a complete rebuild on both forks for about $200, which includes the price of the springs. Go ahead and do it right... don't half ass it. Replace the piston ring, the guide bushings, the seals, and the wipers. As far as taking down the ride... Once you have the forks off the bike, you can rebuild one in about an hour.... It's about 30-45 minutes getting them off the bike, an hour each to rebuild them, and about an hour to get them back on the bike and have the bike rolling. You can easily do it on a weekend afternoon. Just order your parts and have them ready ahead of time. 15 wt oil will work fine. It will add some extra stiffness to the suspension. The forks are nothing more than the equivalent to the springs on a car. The oil and pistons inside the forks are the equivalent to the shock absorber, that supresses the spring bounce. Going to a heavier weight oil, like 15wt, will not allow the springs to oscillate as much due to the viscosity of the oil. It's just like going to a stiffer shock absorber.
#9 (permalink) |
Just for reference sake, how many mile's are on your ride? This could help other's determine future maintance on their bike's.
