This is probably normal, but I want to be sure. I have an Aero 1100, and I get this chirping sound from top end when I am giving the bike gas, Am wondering if there is a way to remove the sound.
Ride to the extreme, but live to ride. be safe. |
#3 (permalink) |
Two things that I can think of is checking to make sure the tank is venting properly, you may hearing air getting sucked through the gas cap. The second thing is lubing your throttle inkage and lube your throttle and speedometer cables.
#4 (permalink) | |
#5 (permalink) |
Too bad we cannot upload sound clips
Thanks, Shandley. ![]() 2004 Honda Shadow Aero VT750C: Punched exhaust. 2005 Honda VTX 1300S: DG Hardchrome, American Classic straight pipes, Backrest, Barons tach, Cobra Light Bar, Triple Whammy lamps, Cobra Passenger & Front Floorboards, K&N air filter, Willie & Max saddlebags, Mustang wide saddle touring seat |
#6 (permalink) |
I hear something similar in sound at low RPM roll on. Consider it normal shaft drive sound. It's a good sound to me.
![]() ![]() 06' 1100 Spirit 71' CL 100 99' Valkyrie Ride Bell by "Yoman" |
#7 (permalink) | |
#8 (permalink) |
When I'm riding solo it isn't an issue. But two up it definitly "tells" me it's time to downshift with it's "stuttering speech syndrone". Weird high geared tranny ratio's on this model of Shadow. 85mph in 3rd gear? Definitly get's you off "I" ramp's quickly.
#9 (permalink) |
chucksshadow,
There`s a couple of things that cause a "chirping" sound on the 1100 AERO`s. Look under the bike, under the motor, and you`ll see "the dog bone". It`s called that because it`s shaped like a dogbone. Spray it down real good with with WD 40 of simular product , and the sound will go away for up to a year. You can remove it , grease it, and put it back for a longer fix. Second, your forks can sqeak from under the fork covers. Spraying some silicone spray using the straw attachment up between the forks and the cover will help. post this question on THE ALL AERO FORUM for more info. ' http://forums.delphiforums.com/hondaaero/start
"All I want to do is ride my machine" [img]
