#11 (permalink) |
Save a bunch of money, go to a exhaust shop and get some pipes that will over your pipes, you'll have a lot more noise and once you have pissed off your neighbors, friends, fellow riders and lost half of your hearing you can go back to stock and it woulden't have cost a arm and a leg
Ted |
#13 (permalink) | ||||
you have a good understanding of exhaust systems however, you're logic is a little flawed, and you're generalizing about a very broad subject. you only covered naturally aspirated engines without catalytic converters, resonators, or mufflers. like a turbo, once you add a cat, resonator or muffler, you add something into the exahust system which causes a tiny, miniscule block in the system, which is known as back pressure.
CAPS LOCK IS CRUISE CONTROL FOR AWESOME |
#14 (permalink) | |||||
I suppose Litnin' could have phrased his response a little better as well. He said, "Again, there is no such thing as 'back pressure.'" Perhaps what he should have said was, "You're not supposed to have back pressure." In other words, if taking out the baffles in your exhaust reduced back pressure THAT WOULD BE A GOOD THING. But again, I'm not a fan of louder pipes. I'm not encouraging this behavior. I'm just pointing out that Litnin' does, in fact, know what he's talking about here. Personally, I think a bike that performs like my 85 Shadow but is as quiet as a full electric would be perfect! - Jon |
#15 (permalink) | ||
Are you an automotive engineer? Have you ever built an exhaust system? No, sorry, there is no such thing as back pressure. No, sorry, a turbo does NOT create back pressure. A turbo works off heat energy by getting expanding gases in to a decreasing size impeller housing. The gases go in to smaller housing and then in to an expansion chamber. The pressure differential of heat energy expanding in to the larger expansion chamber is what causes the impeller to spin. Contrary to what many people believe, a turbo does not work on exhaust pressure, it works off heat energy. On the other end is a compressor wheel which compresses intake air. The deadening effect of the exhaust note is due to the baffling effect that the turbo has as the sound waves pass through it, just like a muffler. Velocity increases, and exhaust pulse pressure rises and falls, but there still is no back pressure. If back pressure existed, the exhaust could not, by the laws of physics, get out of the pipes. Quote:
And no, my logic is now flawed. Your understanding of how exhaust systems work and your "back pressure" buzz word that is so commonly misused is what is flawed.
#16 (permalink) | ||
You are not supposed to have back pressure. Yeah, I can make back pressure if I stuck a potato in the tail pipe and blocked it off. In that case, yes, you have back pressure, which is not good. When a cat goes back and breaks apart, it causes back pressure. Again, not good. However, let me say this... I do believe in one of my previous posts, I did specific that there is no such thing as back pressure in a "properly functioning exhaust system." Quote:
it doesn't reduce back pressure. It changes the exhaust pulse, not the pressure. But I get the idea you were trying to make.
#17 (permalink) |
Just to put a quick 2 cents in on the back pressure and the fact it does exist.
You do want some back pressure. There are 3 things in effect when it comes to the valves in a 4 stroke engine, there is lift, duration, and overlap. When your exhaust valves open, there is a minute amount of time where the intake valves are open as well (overlap). If you don't have enough back pressure, you can suck the fresh fuel/air mixture out through the exhaust valves. Not enough back pressure can cause a lean condition, and poor fuel mileage due to dumping unburned fuel into the exhaust system. Too much back pressure can cause rich conditions and poor fuel mileage due to not having an optimal fuel/air mixture in the cylinder for complete combustion. It is a delicate balancing act. |
#18 (permalink) | |
You are talking about cylinder scavaging and it has nothing to do with "back pressure". The exhaust pulse is what determines cylinder savaging. Not enough back pressure can cause a lean condition huh? Again, tell that to every top fuel race car in the world that run 2 ft open headers. It has nothing to do with being a lean condition. A lean condition exists when your fuel system is not correct for the amount and velocity of air FLOW IN and the exhaust FLOW OUT. NOT back pressure. Oh, and all engines don't have overlapping intake and exhaust valve timing. In fact, most do not... Valve overlap is for high revving performance engines, not low power street engines.
#19 (permalink) |
I put in my 2 cents, if you don't believe back pressure exists, that's your perogative.
However engine exhaust is a gas and follows the laws of physics and fluid dynamics, and every curve and bend, and obstacle in the way of a gas or fluid going through a confined space causes back pressure. EDIT: Oh, yeah one more thing. The average NASCAR Winston cup car gets about 4.5 mpg. They make up for the lean condition by dumping fuel into the system . |
#20 (permalink) | |
No, every curve, bend, and obstacle does not increase back pressure. It decreases exhaust pulse speed and slows down the rate of the exhaust exiting the system. If you had true back pressure, pressure INCREASES velocity, it doesn't decrease it. Add a muffler to an exhaust system and you SLOW the velocity, NOT increase it. And... on the NASCAR Winston cup car... who cares what the mileage is? Yeah, they feed the motor a lot of fuel. That's not making up for a lean condition. That's doing exactly what I said and keeping the fuel mixture correct for the volume and velocity of incoming air and out going exhaust. You know what we run in nitro motors? We put 18 gallons of fuel through the motor in 1/4 mile. That's 72 gallons of fuel in less than 20 seconds in 1 mile. Ya know what? We aren't compensating for a lean condition. That's how much fuel it takes to keep the mixture correct for the volume and velocity of air we push the the motor. A street car runs less volume and lower velocity in and out and therefore needs less fuel to keep the mixture correct. Back pressure has NOTHING to do with it.
