Need. More. loud!!!!!! - Honda Shadow Forums : Shadow Motorcycle Forum
Old 05-20-2009, 01:07 AM   #1 (permalink)
Default Need. More. loud!!!!!!
I have a 2001 Shadow VLX 600, I currently have Cobra Classic Slash cuts on it, but it's still not loud enough. What pipes can I get to make it louder?
I intend to live forever, so far, so good.
2005 Shadow Spirit 1100
frankjt96 is offline   Reply With Quote
Old 05-20-2009, 07:16 AM   #2 (permalink)
Toxic ACE's Avatar
Probably drag pipes.........but if you ride much ....well make sure and bring Asprin and a new battery for the hearing aid you will soon need.
__________________________
1995 Honda Shadow ACE 1100 (R.I.P.)
Toxic ACE is offline   Reply With Quote
Old 05-20-2009, 11:12 AM   #3 (permalink)
mxs
Default Re: Need. More. loud!!!!!!
Remove the ones you have and be done with it ...
And people wonder why a non-riding public dislikes bikes on the road ....
mxs is offline   Reply With Quote
Old 05-20-2009, 11:21 AM   #4 (permalink)
Move much further South...the irregular shape and consistency of the Snow banks must be absorbing a high % of the sound waves vs reflecting them...
My SlashCuts on the 94 VLX 600 are quite loud. Maybe we could trade if they will swap-out..
Charlie S - War Eagle!
06 VT 750 Shadow Spirit
94 VT 600C VLX (Donated to Sis-in-Law 4-23-10)
Concerned about gun control...use Both hands.
86 Suzuki Intruder 700
Landlrd2 is offline   Reply With Quote
Old 05-20-2009, 12:28 PM   #5 (permalink)
Send a message via MSN to meatpopsicle
can you remove the baffles?
I took mine out but that way too loud. I cut the baffles took out about 1/3 of the "baffeling" area and welded back together. perfect!
I also have cobra long shots
Some people ride to get from point "A" to point "B", I ride to escape Both Point "A" and Point "B"
meatpopsicle is offline   Reply With Quote
Old 05-20-2009, 09:50 PM   #6 (permalink)
No, taking out the baffles is a bad idea. It will mess with your back pressure and eventually destroy your valves As far as noise, it's not a "Hey! look at me and my loud bike" factor. It's personal preference. I like loud things, minus loud girls
J/K
Anyhow I've heard drag pipes will do that. How hard would it be to fabricate my own pipes?
Old 05-20-2009, 11:11 PM   #7 (permalink)
litnin's Avatar
I don't know who told you that, but that is not correct.
#1. There is no such thing as back pressure in an exhaust system.
That's a term that's thrown about by people who use it as a buzz word
and don't know how exhaust systems work.
#2. No, it won't burn your valves. If it did, every race car on the planet
would blow up when it ran, because the open headers they run would
be 10x's worse that removing a set of baffles in an stock or mildly tuned motorcycle.
There are plenty of motorcycles out there running straight pipes.
Yes, going straights will probably require a rejet, but it's not going to burn valves.
litnin is offline   Reply With Quote
Old 05-20-2009, 11:32 PM   #8 (permalink)
It's a 600. Sounds to me like you really want to sound like a bigger bike than you have. Am I close?
DoobieBrother is offline   Reply With Quote
Old 05-20-2009, 11:57 PM   #9 (permalink)
http://www.aa1car.com/library/exhaust_backpressure.htm
read.
CAPS LOCK IS CRUISE CONTROL FOR AWESOME
balactm is offline   Reply With Quote
Old 05-21-2009, 12:23 AM   #10 (permalink)
litnin's Avatar
read.
...and? That doesn't make it correct.
Again, there is no such thing as "back pressure."
I'm quite familiar with exhaust systems and how they work.
Exhaust systems work on pulse pressure and flow velocity, NOT back pressure.
You cannot, under any correctly functioning exhaust system read a steady pressure.
You CAN however, read Pressure PULSES as they travel through the exhaust system.
Exhaust pulses travel in two phases, high and low.
The leading edge of the pulse is the high side and the trailing edge is the low side.
As one pulse travels through the system, the low side of one helps pull the high side of the one behind it.(Natural physics).
High pressure always moves to low pressure. That doesn't mean it backs up and creates "back pressure".
As I said, people throw it around as a buzz word because they don't know
or understand how an exhaust system really works.
