Opinions about a tire leaking? - Honda Shadow Forums : Shadow Motorcycle Forum
Old 05-21-2009, 08:04 AM   #1 (permalink)
Default Opinions about a tire leaking?
My wife pointed out yesterday that my front tire was flat. I put the bike on the lift and leak checked the rim/tire/valve etc. (sprayed with soapy water and looked for bubbles). Didn't see a leak.
My question is, if the tire does have a leak, would you REPAIR it or REPLACE it? I know it's probably a matter of how safe I wanna feel, I'm just curious as to how many of ya'll have repaired tires and kept on crusin'?
child of God
jbfan is offline   Reply With Quote
Old 05-21-2009, 09:11 AM   #2 (permalink)
adlowe's Avatar
Depends on the leak. I wouldn't hesitate to ride thousands of mile on a tire with a patched hole in the tread; I wouldn't ride 5 miles on one with a leaking cut in the sidewall.
You've got spoked wheels. That means you've got tubes in your tires. Before replacing a leaking tire -- when you can't find the leak -- you should look at replacing the tube and the strip of rubber (can't remember what it is called right now) that goes around the rim underneath the tube. If it is the front tire, it wouldn't take much time or effort to change both.
Art's 1999 Shadow 1100 ACE
adlowe is offline   Reply With Quote
Old 05-21-2009, 01:59 PM   #3 (permalink)
Three things that are not long hidden; the sun, the moon and the truth.
2005 Aero
1972 Honda XL250 Motorsport
2006 Rebel - daughter (Now gone)
1974 XL100
thunderglass is offline   Reply With Quote
Old 05-21-2009, 07:22 PM   #4 (permalink)
Last leak I experienced was a bead leak - had to fill a wheelbarrow with water to find it. Busted the bead cleaned it up and and re-seated -good to go.
Cbjr is offline   Reply With Quote
