ACE VT1100 Gas Tank Replacement - Honda Shadow Forums : Shadow Motorcycle Forum
Old 05-23-2009, 08:50 AM   #1 (permalink)
Default ACE VT1100 Gas Tank Replacement
hey guys. i have an ACE VT1100 97' and i'm looking to give to my bike a "thinner" look. now, i did some things but it all comes down to the gas tank. its way too fat. do you know if there are specific models of the shadow line that might fit instead of the one i have know?
thanks.
Dreamfortheblind is offline   Reply With Quote
Old 05-23-2009, 09:46 AM   #2 (permalink)
ohiospirit1100's Avatar
the tank from the 1987 to 1996 shadow 1100 will bolt up with to problem. it holds 3.4 gals. and is thinnner than your tank that holds 4.3 gal. i did the switch the other way around on my bike so i have .9 gal more fuel to burn!
ohiospirit1100 is offline   Reply With Quote
Old 05-23-2009, 11:05 AM   #3 (permalink)
Default .
thx, but i still think that less capacity will be a problem. i tried with a 1995 Honda VT 1100 C Shadow that has the same capacity but it only fits with my original stock seat and not the custom i had installed.
Old 05-23-2009, 11:07 AM   #4 (permalink)
adlowe's Avatar
Default Re: .
Seems like you're going to have a problem getting a thinner tank with the same capacity.
Thought about getting one custom built?
Art's 1999 Shadow 1100 ACE
adlowe is offline   Reply With Quote
Old 05-23-2009, 11:15 AM   #5 (permalink)
i did, but i dont know where i can find someone to do it. anyhow this way it would be much cheaper but it seems that i cant do it. do you know anyone that actually makes custom gas tanks by order? and if its possible to order via internet?
Old 05-23-2009, 11:43 AM   #6 (permalink)
adlowe's Avatar
Nope, never done it. But here are some possibilities:
http://www.custom-choppers-guide.com...-gas-tank.html
http://ezinearticles.com/?How-to-Sel...ank&id=1313230
http://www.rccomponents.com/custompr...toiltanks.aspx
http://www.lickscycles.com/catalog/default.php?cPath=41
Old 05-23-2009, 12:08 PM   #7 (permalink)
thank you. really appreciate the trouble. i will look into it and i'll decide what to do.
