I have VT 800 and the clutch would not bleed properly, meaning it would bleed but stay spongy, so I tried much sorter brake hose and it worked great. So I went on ebay and got clutch cable from vt 1100 bent it the way i need and the same thing it would stay spongy, I was screwing with it for 2 hours bleeding the whole bottle of dot4 and nothing. I left it and went on doing something else occasionally squeezing the clutch lever when i was around the bike. After 3 days I felt it started "getting hard"lol. I could not believe it. It works now. Is the longs of the hydraulic line makes that much difference? 3-4 hours vs 15 minutes of bleeding time?
Matrix has you. Free your mind. ![]()
A long hose can make the brakes feel soft, not spongy, air makes them feel that way and what most likely happened was while setting the air migrated up to the bowl and your brakes got better, no miracle just less air.
Ted |
#3 (permalink) |
I had a similar problem with my previous VT800.
I found the key was bleeding through the banjo fitting at the reservoir on the handlebars. Air would trap at the top of the hydaulic line and could only be bled out under pressure at the banjo. Cheers, Haze
![]() Haze Shadow Ambassador "CRAP" Cheapskate Riders Are Proud www.Crapmods.com Ride Bell by Kara Patriot Guard Rider 2006 - ST1300 Mazy - The stealth fighter 2002 Shadow Spirit 1100 - Sold Member of the Colonial Cavalry |
#6 (permalink) | |
#7 (permalink) |
[quote=Slowly give your clutch handle several squeezes (make sure you keep your reservoir topped up)[/quote]
Should I open lower banjo bolt before squeezing the lever? . BTW if I keep the front wheel straight all the brake / clutch fluid will spill or I should put the cover on. Thanks
#9 (permalink) | |
[quote=moneyend]
You only need to keep pressure on the lever when you are closing either the top (reservoir) banjo bolt or the lower bleeder.
