Chime for turn signals - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
Old 06-01-2009, 11:03 PM   #11 (permalink)
RJDoles's Avatar
The buzzer was standard with my 84 Elite 125 scooter.
It also gets more aggressive the longer the signals are on. Every time the light blinks for the first 30 seconds it sounds one beep. After about 30 seconds, every time the light blinks, it sounds two beeps and so on.
I don't know why Honda didn't put it on all their bikes.
There is something about being out in the wind on two wheels that brings a SMILE to my face.
58 Allstate Cushman when I was 14 years old
66 305 SuperHawk
70 CB750 Honda when I got out of the service
76 Kawasaki 175 Enduro
76 Suzuki TM400 what a killer
78 RD400 Yamaha
99 Shadow VLX about 25 years later
84 Elite 125 got it for my wife to learn on
05 Reflex my wife's ride
07 Majesty totaled November 2011
05 Silverwing
03 750 Spirit my current ride
RJDoles is offline   Reply With Quote
Old 06-03-2009, 10:24 AM   #12 (permalink)
Shandley's Avatar
Alright! I did it last night. Two diodes connected at the banded end and that lead goes to the POS of the son alert. The negative to a good ground. I ran the other two leads off of the diodes to the connectors under the seat right by the rear fenders. I spliced the wires together and like a charm, it works.
One thing I noticed: While I was riding and turning, I found myself cancelling the turn signals before I even thought about being reminded by the chime.
Huh... did I need to do this? LOL
Say, does anyone know where I can get those Blue and Orange connectors from? I will post a pic for those who do not know what I mean.
Thanks,
Shandley.
2004 Honda Shadow Aero VT750C: Punched exhaust.
2005 Honda VTX 1300S: DG Hardchrome, American Classic straight pipes, Backrest, Barons tach, Cobra Light Bar, Triple Whammy lamps, Cobra Passenger & Front Floorboards, K&N air filter, Willie & Max saddlebags, Mustang wide saddle touring seat
Shandley is offline   Reply With Quote
Old 06-03-2009, 12:07 PM   #13 (permalink)
goodies's Avatar
I actually just install a turn signal beeper on my VLX. It works great!!
Here are the instructions I went with and it only required 1 buzzer and one rectifier, and was fairly simple to install.
http://2wheelerjay.tripod.com/id3.html
same thing different link
http://www.ldrider.ca/techpages/turnsignalreminder.htm
goodies is offline   Reply With Quote
Old 06-03-2009, 12:10 PM   #14 (permalink)
Shandley's Avatar
Here are the instructions I went with and it only required 1 diode, and was fairly simple to install.
Very nice! Mind you, it's a rectifier, which is essentially 2 (or sometimes 3 or 4 or 6) diodes. Way to go!
Thanks,
Shandley.
Old 06-03-2009, 12:13 PM   #15 (permalink)
goodies's Avatar
I do find that I am really in a hurry now to shut them off, especially sitting at a light. You really want to make the noise go away.
Old 06-03-2009, 12:19 PM   #16 (permalink)
Shandley's Avatar
Ha! How about when another rider pulls up beside you? Doesn't it make you want to turn them off?
Thanks,
Shandley.
Old 06-03-2009, 12:26 PM   #17 (permalink)
goodies's Avatar
Nah, I'm a girl so I can get away with alot more. LOL!
Old 06-03-2009, 12:27 PM   #18 (permalink)
Shandley's Avatar
Lucky!
Thanks,
Shandley.
Old 06-03-2009, 12:32 PM   #19 (permalink)
litnin's Avatar
All those diodes are not necessary, that's just a lot of extra wiring and
work that isn't needed.
Wire the buzzer in at the flasher relay.
Power goes in to the flasher relay and then to the switch, which determines left or right indicator function.
If you wire the buzzer in between the switch and the flasher relay,
there is no need for diodes.
litnin is offline   Reply With Quote
Old 06-03-2009, 07:09 PM   #20 (permalink)
Haze's Avatar
Relay to turn off signal buzzer.
I built the same turn signal buzzer circuit for my 1100 spirit this past weekend. Used a radio shack 75 dB 12v piezo buzzer and wired in parallel to the turn signal flasher. No diodes needed. I also added a Radio Shack 12V (NC) Normally Closed relay in series with the buzzer. I trigger the relay with a wire from the brake circuit. Whenever I hold the brake such as at a stop light the buzzer is shut off and the signal flashers continue to flash.
My piezo buzzer and relay are mounted to the signal flasher with double sticky tape. Every thing is placed in the stock location inside the neck cover.
cheers,
Haze
Haze
Shadow Ambassador "CRAP" Cheapskate Riders Are Proud
www.Crapmods.com Ride Bell by Kara
Patriot Guard Rider
2006 - ST1300 Mazy - The stealth fighter
2002 Shadow Spirit 1100 - Sold
Member of the Colonial Cavalry
Haze is offline   Reply With Quote
