I have a 02 shadow sabre and I would like to bring it no more than 1" closer to the ground. no more! Maybe actually more like 3/4" drop.
I want it for the comfort of feet on the ground and appearance. Also better handling would be a nice benefit if it is one. Have you guys done it? I want to use quality parts and not just a hack job. Where do I start?
UNDER CONSTRUCTION
#4 (permalink) |
1 1/2 is bad enough but 2",,,,,,well you Might try thinking where the heck the tire is going to go when you hit a bump and where your going to put the wires that are inside the top of the fender.
Ted |
#6 (permalink) |
The front fenders on the Sabres are attached to the lowers on the forks so the fender travels the same amount as the wheel. They will not touch each other.
===================================== Wasn't talking about the front fender, you can get by with a lot on the front , it's the back one has to worry about, eliminate 50% of the room for the tire to travel and you will have a problem sooner or later.
Ted |
