Vt700 carb interchange - Honda Shadow Forums : Shadow Motorcycle Forum
Old 06-14-2009, 08:07 AM   #1 (permalink)
Default Vt700 carb interchange
I was wondering if the 83-85 vt700 carbs would swap onto the 86-87 vt700 ?
Is it possible to use the 83-85 jet kit? I need the needle part.
The previous owner punched the baffles out of mine and it has a miss between 2500 and 3800 rpm that is from being lean, and there seems to be no jet kit for the 86-87 models to get it tuned.
2003 RE Bullet, 1992 Vulcan 1500, 1978 Cb750K,
1976 Kz900/ Ural sidecar. 1971 Cb750 chopper project. 1970 Cb750K Pictures at: http://www.flickr.com/photos/27246804@N04/
oldbike is offline   Reply With Quote
Old 06-14-2009, 10:14 PM   #2 (permalink)
tubes_rock's Avatar
I'm not aware of a kit, but I know that the 1984/85 kit will not fit the 1986 carbs.
You don't need a kit. Just bump the main jet up two sizes, and the slow jets one or two sizes. (depending on where you like your pilot screws set)
If it's a matter of needing the needle, you can just re-order the stock needle from a Honda shop and use bigger jets to make the mixture richer.
--Justin
2010 Honda NT700V
1986 Shadow 700
Old 06-15-2009, 07:08 AM   #3 (permalink)
Thanks Justin. I will get a small range of upward jets on order and fiddle with them.
