Coolant tempreture light comes on - Honda Shadow Forums : Shadow Motorcycle Forum
Old 06-18-2009, 09:56 AM   #1 (permalink)
Default Coolant tempreture light comes on
After riding my 2003 Saber for an hour or so my tempreture light will come on, flicker then go out. This cycle will repeat itself every 15 minutes or so. The fan is working, Fluid levels are fine. It has me baffeled. Do I have anything to worry about? Any information would be greatly appriciated.
keith4031 is offline   Reply With Quote
Old 06-18-2009, 07:14 PM   #2 (permalink)
RJDoles's Avatar
Assuming that the coolant level is correct.
It could be that the temperature switch for the light is turning on at too low of a temperature. I think that all the Shadows are similar and the switch points listed in my VLX service manual state, the light should switch "ON" as the temperature exceeds 260 deg F. and switch "OFF" as the temperature drops below 252 deg F.
It could be that the temperature switch for the fan is turning on at too high of a temperature. The fan should switch "ON" as the temperature exceeds 216 deg F. and it should switch back "OFF" as the temperature drops below 207 deg F.
If the light comes on while you are driving then it is likely the light switch or a thermostat problem. If it only comes on when the bike is sitting and the fan is running then it could be either one of the switches or the thermostat.
Does the light come on just before the fan cycles on and then it shuts off after the fan has run for a few seconds?
Ride safe.
There is something about being out in the wind on two wheels that brings a SMILE to my face.
58 Allstate Cushman when I was 14 years old
66 305 SuperHawk
70 CB750 Honda when I got out of the service
76 Kawasaki 175 Enduro
76 Suzuki TM400 what a killer
78 RD400 Yamaha
99 Shadow VLX about 25 years later
84 Elite 125 got it for my wife to learn on
05 Reflex my wife's ride
07 Majesty totaled November 2011
05 Silverwing
03 750 Spirit my current ride
RJDoles is offline   Reply With Quote
Old 06-18-2009, 07:53 PM   #3 (permalink)
The light comes on when slowing down. On a recent long trip (that Started it all) the light would com on briefly while moving tehn go out.As soon as the fan kicks in the light flickers and the goes out. Today I put antifreeze in the radiator, and the resivor was full. After riding, the over flow worked like it is supposed to. I am assumiing that this means that I have good flow. I used a infer red temreture gauge on it today. The return line coming out of the radiator was 165 the hose coming out of the rear of the engine was above 240. Does this help any?
