Gear shift linkage bent.... - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 12 (permalink) Old 07-18-2009, 03:37 PM Thread Starter
Has anyone ever had any issues with the linkage that runs between the gearshift pedal and the gearshift drum being bent??
It makes it tricky sometimes getting into some of the lower gears from time to time.
I'm thinking about replacing it and want to confirm that it is part #14 in the attached picture for my 2001 Honda Shadow ACE 750, correct??
http://fiche.ronayers.com/Index.cfm/...76/Group/PEDAL
Thanks in advance for the help!!!
Motorcycle newbie getting VERY addicted to riding this sweet '01 ACE!!
Aka...Gary....
alidog1974 is offline
post #2 of 12 (permalink) Old 07-18-2009, 08:59 PM
TechJD's Avatar
looks right
At Honda it's about $7.00
1996 VT1100C2 Shadow ACE (Blue Bike in Pic is 1983 CMX250 - was Son's)
TechJD is offline
post #3 of 12 (permalink) Old 07-18-2009, 09:52 PM
It's a straight rod so why don't you remove it, lay it on a hard flat surface and tap it with a hammer until straight. Looks like it would be an easy fix but I've been wrong before............................just ask my wife.
Three things that are not long hidden; the sun, the moon and the truth.
2005 Aero
1972 Honda XL250 Motorsport
2006 Rebel - daughter (Now gone)
1974 XL100
thunderglass is offline
post #4 of 12 (permalink) Old 07-19-2009, 02:49 AM
+1 on straightening it, take your time and get it as stright as you can because once it's bent it has a weak area that can bend again, the only time you could bend it is going to first the rest of the time your pulling up except for down shifts which don't require any real pressure, sometimes getting into frist can be a little troublesome but if you just let the clutch out a bit is will aline things and it will go right in,,,,,most of the time.
Ted
SHADOW 1100T is offline
post #5 of 12 (permalink) Old 07-19-2009, 07:47 AM
We already did ask her. She said to ask you if you remember that time you were standing in the woods talking to yourself and she wasn't there to hear you. She said you were wrong then too!
Schattenreiter is offline
post #6 of 12 (permalink) Old 07-19-2009, 11:13 AM
Super Moderator
CleoBen's Avatar
I would suggest a hard, flat, wooden surface, so you don't damage the threads on the ends.
CB
CleoBen is offline
post #7 of 12 (permalink) Old 07-19-2009, 07:05 PM
What she failed to say was that I picked up that bad little habbit from HER!
I do hear voices at times.....................but then I sober up.
2005 Aero
1974 XL100
post #8 of 12 (permalink) Old 07-19-2009, 08:56 PM
If I ask her will she straighten my rod too...
Sorry couldn’t resist
Jason
95 1100
salt17 is offline
post #9 of 12 (permalink) Old 07-19-2009, 09:24 PM
hlaltimus's Avatar
That left & right hand threaded rod isn't all that thick in diameter. Easy fix if you don't scratch it up. Place it between two softwood blocks, (each at the outer ends but neither in the middle,) and progressively bump it once or twice at exactly it's area of deflection with a rubber mallet until it's realigned. Nuts are matched to each end.
Pleasure is directly proportionate to risk, and motorcycles are inherently pleasurable.
H. L. Altimus
2003 VT1100C2 Sabre
hlaltimus is offline
post #10 of 12 (permalink) Old 07-19-2009, 10:45 PM
I think you could have if you tried.
'98 Shadow 1100 ACE
Notorious is offline
