Carb cleaning: boiling lemon juice vs. chem dip - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 10 (permalink) Old 09-04-2009, 12:41 PM Thread Starter
brock29609's Avatar
Anyone have first hand experience boiling a carburetor in lemon juice to get it cleaned? I've read it's as effective or more than those harsh chemical dips.
Can I clean my carb thoroughly and save the planet at the same time, or is this too good to be true?
Former Shadow Owner - Greenville, South Carolina
brock29609 is offline
post #2 of 10 (permalink) Old 09-04-2009, 01:35 PM
rat
The lemon juice is highly acidic... and can eat away at the aluminum. When you're dealing with carb, where tiny, tiny changes can affect tuning... is it worth it?
Stick with carb cleaner.
Later, folks.
rat is offline
post #3 of 10 (permalink) Old 09-04-2009, 01:40 PM
Don't boil in lemon juice I've heard soaking in lysol works pretty well. But the best is of course carb cleaner, it's made for just that job.
qwertydude is offline
post #4 of 10 (permalink) Old 09-04-2009, 01:55 PM Thread Starter
brock29609's Avatar
Aren't all the passage ways that matter brass?
post #5 of 10 (permalink) Old 09-04-2009, 02:53 PM
rat
Yup.
But that brass is seated/threaded, pressed into aluminum. All the flat mating surfaces are aluminum, your pilot screw and passges? All aluminum.
Your call.
Later, folks.
rat is offline
post #6 of 10 (permalink) Old 09-04-2009, 02:56 PM
Lemon juice ain't made for cleaning carbs.
Industrial carb cleaners are made for cleaning carbs.
Gnuiser is offline
post #7 of 10 (permalink) Old 09-04-2009, 03:31 PM
litnin's Avatar
Lemon juice is perfectly fine for cleaning carbs if you are sensible about it.
The EPA over the last several years has been cracking down on
harsh chemicals like carburetor and parts tank cleaners.
With this crack down, almost all parts tank cleaners are a citrus based
cleaner that is comprised of orange and lemon juice.
While not as effective as the good old carb cleaner, it will work and it
wont' hurt anything. Obviously, don't throw it in and leave it sit
for weeks on end, but an over-night soak won't hurt a thing.
If you use it, I would suggest afterwards, washing it down with a good
base of some sort to make sure all cleaning (acidic) action has stopped.
litnin is offline
post #8 of 10 (permalink) Old 09-04-2009, 10:23 PM
tubes_rock's Avatar
And to add to what litnin said, run the lemon juice through two coffee filters first. You don't want any of the pulp stuff to get stuck in the passages.
--Jusitn
Currently Running Stable:
2010 Honda NT700V
1986 Shadow 700
1987 Honda Rebel 450
1973 Honda Mini Trail 50
tubes_rock is offline
post #9 of 10 (permalink) Old 09-04-2009, 11:25 PM
litnin's Avatar
--Jusitn
Excellent suggestion!
litnin is offline
post #10 of 10 (permalink) Old 09-07-2009, 07:03 AM
toyfarm's Avatar
I always use lacquer thinner, works great.
toyfarm is offline
